Thread: Trichlor and pool calculator
    Oct 2009
    Southern CA
    54
    If trichlor is used as a source of chlorine (vacation), does the pool calculator take into consideration of its effects on pH in the acid needed section? In other words, is the amount of MA calculated lowered because of using trochlor?
    Irregularly shaped IG pool with aggregates of squares and rectangles, spa overflows to pool
    21K gallon, Pebble tec, 450 sq ft, 125 GPM cartridge filter, 1hp pump, 1.5hp booster pump, Jandy heater,
    2 skimmers, 2 main drains, Hayward Navigator automatic vacuum connected to one of the skimmers
    Re: Trichlor and pool calculator
    No. Each chemical is treated separately, with only one exception. The current TA level is taken into account in the PH calculation. Otherwise everything is calculated independently.
    Oct 2009
    Southern CA
    54
    Thank you.
