Thread: Question about returns
    I know that you get the best benefit of chemicals if the returns are pointed in a downward direction. What is the best way to turn the eyeball to maximize the skimmer function, if your using a downward left or right direction. All of them facing the same direction to create a circular current past all the skimmers or using the two closet eyeballs to a skimmer one pointing left the other right towards the skimmer. Thoughts welcome, success stories.
    Mar 2011
    Scottsdale, AZ
    406
    Re: Question about returns
    Generally getting the water to move in one direction will help debries get to the skimmer.
    22,539
    I've found that by pointing the eyeball up to where it barely ripples the surface and all the way to one side works best at getting the stuff to float toward the skimmer. You have to play with it to get the best results.
