Results 1 to 12 of 12
Thread: Valve ID (Identifying my Valves)
    Hello All,
    This seems like a good place to start my journey on maintaining my new pool. I moved into a house with an existing 6-10 year old in ground pool.
    -AO Smith SQ1152 1.5HP
    -15K Gal
    -Jandy JS100-SM Sand Filter
    -Pop Ups
    -In Ground
    -Pebble
    I am trying to identify all my valves as the existing markings have since come off. I have made out a few but would still like some input on my particular setup and ideal settings (please see below picture).
    I have figured out most of the inner workings of the pool and my valves. But, what has troubled me is the vacuum intake line on the side of the pool. I have been trying to get suction to vacuum the ground of my pool as it is very dirty. This hose line on the side of the pool has threads in it and seems to run into leaf catcher skimmer type thing in another access hole next to my skimmers top entrance.
    I appreciate all the help in identifying these valves to better my luck in getting suction. And of course look forward to some great help here on the forum.
    Thanks
    *****UPDATED 4/15
    Here are some requested pics of skimmer and other access hole thing.
    *-Arizona-*
    -15K Gal
    -Pop Ups
    -In Ground
    -Pebble
    22,553
    Re: Valve ID (Identifying my Valves)
    Looks like you have a skimmer and main drain(s) pulling equally from the pump. You may have to shut off the MD completely to get enough suction through the suction wall fitting. You may also have to adjust the skimmer to pull from this port. Post a pic of the skimmer and the vacuum port and basket.
    crookm11's Avatar
    Jun 2010
    Copperas Cove, Texas
    422
    Quote Originally Posted by kntdookoo
    Hello All,
    -15K Gal
    -Pop Ups
    -In Ground
    -Pebble
    Thanks
    Welcome to TFP!
    On your picture you have an arrow labeled as aerator, is that pointing to the blue hose or the valve behind the hose? If it is pointing to the blue hose do you have the hose going in to the pool to aerate the pool? I think the blue hose is connected to the backwash port of the filter and that is used to drain off the debri in the filter. Just a thought.
    Mark Crook
    13,500 Gallon 24' x 52" Intex Ultra Frame
    Intex Sand Filter and Pump, Intex SWG (All hard PVC plumbed)
    TFTestKit-100---Pool School---The Pool Calculator
    Location: Copperas Cove, Texas --- My Pool Build---Useful Links for Intex Pool Owners
    The Aerator labled arrow is pointing at the valve. The blue hose runs to the side of yard so I assume that is for backwash. Also, keep in mind I did my best to read the old markings on these valves though most not so legible. So, they may be incorrect.
    See updated pics above of skimmer basket (which has no hole in the bottom for a hose, and other access hole thing with a locked clear turny thing)
    *-Arizona-*
    -15K Gal
    -Pop Ups
    -In Ground
    -Pebble
    Mar 2011
    Scottsdale, AZ
    406
    First if you take the Equalizer assembly (donut thing) in the bottom of the skimmer out you will see two holes.
    One of those goes directly to the pump suction. Usually the back one.
    Looking at the pictures it appears you have a Paddock pool, and your infloor is a PCC 2000.
    The other thing is a debris containment canister.Here is a link that shows it.http://www.paramountpoolproducts.com/products/pcc/
    So the pump connects to the bottom of that, then there is a port that connects to a funny looking single drain at the bottom of the pool, and that port in the side probably connects to that same drain, as a safety. Though it should have a drain cover over it. Now their
    Let me know how I did with my speculation.
    Mar 2007
    Coastalish 'down easter'
    4,160
    Welcome to TFP!!
    I think the other posters have given you a good idea of what you're dealing with
    I see from the pics (THANKS for the pics ) that you have an iron issue in your water If you start a new post, on the iron issue, our stain experts will help you with it
    Luv& Luk
    -Ted
    Thanks to all for your posts. I will definately start a new thread in regards to the iron. What exactly did you see in my pics that showed you I have such a problem?
    Also, anymore ideas on how to get my vacuum working. 2 posts back it was mentioned to take out the equalizer. I did. There are two ports underneath. Can I vacuum directly into that?
    *-Arizona-*
    -15K Gal
    -Pop Ups
    -In Ground
    -Pebble
    Mar 2011
    Scottsdale, AZ
    406
    Yes one of those pipes goes directly to the pump so you can attach the vac there.
    Great thanks guys. Just vacuumed my pool via the skimmer. Everything went well. Good suction and now the bottom of the pool is dirt free.
    Next, on to my iron problem and chemical balancing.
    *-Arizona-*
    -15K Gal
    -Pop Ups
    -In Ground
    -Pebble
    Mar 2007
    4,160
    Welcome to TFP!!
    Quote Originally Posted by Just-a-PB
    You can certainly do that, but it's better to have something to catch the larger debris They make 'covers' that go over the skimmer basket and accept your vacuum hose, or there are 'large debris' collection cannisters that will attach to your vac hose.
    Keeping as much stuff, as you can, from getting to the pump (and it's impeller) is always a good idea
    Luv& Luk
    -Ted
    Dec 2010
    San Diego, CA
    1,137
    So is that debris collection system working? It looks plugged up...
    15,600 Gallon, 16' x 32' In-Ground Vinyl Pool
    Pentair VS 3050 pump, Quad DE 60 filter and SunTouch controller
    8 gallon Liquidator, Aquatherm EcoSun Solar Panels, 2 wheel ThePoolCleaner
    Yes it seems to be working. When I remove the locking lid and pull the long mesh sock thing out there was some debris in it. When the pump is running I can see flowing water running through it.
    *-Arizona-*
    -15K Gal
    -Pop Ups
    -In Ground
    -Pebble
