Results 1 to 20 of 20
Thread: Adding Salt
    Adding Salt
    Today I added about 1/2 bag of salt to my SWG pool. It was below 3,000 and I wanted to raise it a little. After I added the salt, I did not turn off the SWG. I just read that I was suppose to leave on the filter but turn off the SWG. What type of problems might I have because I didn't turn off the SWG. Should I turn it off now? If so, for how long?
    I am still learning about maintaining my pool.
    Thanks for your help!!
    East TN
    13,000 gal San Juan Fiberglass Pool;SWG; GoldLine Pro Logic Controls
    Hayward Sand Filter; Hayward Max-Flo XL Pump;Polaris 380; Hayward ColorLogic LED
    Raypak Gas Heater
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Adding Salt
    As long as you didn't add your salt directly to the skimmer, but instead added it to the bulk pool water with sufficient mixing (i.e. not just getting into a floor drain), then there should be no problem. The reason they say to turn off the SWG is to prevent any concentrated salt water from causing the SWG from burning out due to excessively high water conductivity and therefore current through the SWG.
    Re: Adding Salt
    Thank you so much!! I feel so much better. I added my salt throughout the pool not in the skimmer. Would you still recommend that next time I add salt that I turn the SWG off for a few hours?
    Thanks!!
    East TN
    Raypak Gas Heater
    Dec 2009
    Central Massachusetts
    2,690
    Re: Adding Salt
    I've never turned mine off when I've added salt.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    Re: Adding Salt
    Quote Originally Posted by bk406
    Being lucky isn't quite the same thing as being trouble free, though they are similar
    There is a risk of completely destroying the SWG if it is on when you add salt. In practice, the great majority of the time nothing will happen. But why risk even a 1 in 10,000 of destroying your SWG. The actual risk depends on details of your plumbing and brand of SWG, but why risk it at all?
    Dec 2009
    2,690
    Re: Adding Salt
    Quote Originally Posted by Strannik
    doesn't matter if you don't add it to the skimmer
    I think the idea of not adding salt when the SWCG is more of a myth than anything. If anybody can document an actual case of damage directly related to it (added to the bulk pool water that is) and not just some theory, post it up.
    I could see an issue if it were added directly to the skimmer. But imo, nothing should be added directly into the skimmer
    Jul 2007
    Brisbane, Australia
    874
    Re: Adding Salt
    ummm, having worked at a company that manufactures SWG and having done lots of testing I can assure you that if you put enough salt in, the transformer will burn out before the high salt alarm will turn the unit off. that is if the unit even has high salt alarm
    Dec 2009
    2,690
    Re: Adding Salt
    How do you square these 2 statements;
    Jul 2007
    Brisbane, Australia
    874
    Re: Adding Salt
    there is no contradiction there.
    to raise salt level fast you need to add it to the skimmer, there is no other way. if you don't raise it rapidly, then the high salt safeguard (assuming the unit has one) will turn the unit off before the conductivity becomes too high.
    Re: Adding Salt
    Wouldn't salt that went into the main drain, assuming there is one, cause exactly the same issue as the skimmer?
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Adding Salt
    I would think so which is why I wrote about that in my original post. I've sometimes added certain chemicals that didn't dissolve completely very quickly and swept the remnants to the main drain to either dissolve or get caught in the filter and eventually dissolve. Certainly, if one adds salt too quickly in the deep end, it could get to the main drain in concentrated form and potentially cause a problem.
    I agree with Jason that since it's so incredibly easy to turn off the SWG during the salt addition process, one might as well do this when adding salt to the pool, just in case. Once one has added it all and sees that there aren't any piles undissolved and that things have circulated for a bit (even 10 minutes or so), then one can just turn on the SWG again.
    Dec 2009
    2,690
    Re: Adding Salt
    Quote Originally Posted by chem geek
    it's so incredibly easy to turn off the SWG during the salt addition process, .
    Not to argue the point (well maybe a little), but if the SWG is tied to the pump, it's not at all easy to turn it off since the pump needs to be running in order to help disperse the salt.
    Re: Adding Salt
    Just set the percentage to zero percent.
    Jun 2013
    Wilmington, NC
    6
    Re: Adding Salt
    Actually, just the other day I was adding 40 lbs of salt to my pool for the first salt re-up. I was caught up in the fact that I was being such a responsible pool owner and was paying close attention to my salt levels for several months now. It was the first time topping up on salt, I was in a rush, and I didn't think it through and added about 15lbs of the 40lbs directly to the skimmer. SWG was on the whole time. Now I have a check cell light going on my SWG. I took the cell out and visually inspected it and it seemed fine (ie: no visible scaling on plates). It's still producing adequate chlorine, but I'm assuming I need to do a mild acid wash to get the check cell light to stop blinking.
    So moral of the story, definitely turn your SWG off, because they do get damaged, however minor. Any advice would be appreciated.
    Edit: My sig's out of date. Circupool Si60 SWG.
    36,000 Vinyl Pool, all day sun. Si-60 SWG, Hayward S-200 Sand Filter, 710X32 Multi-Valve, 1.5 HP Pump. Taylor K-2006 test kit, BBB method.
    May 2014
    Mesa, Arizona
    180
    Re: Adding Salt
    Salt should be broadcasted in the shallow end of the pool with the SWG off. After broadcast, sweep the coagulated salt throughout the pool until fully dissolved and run filter for 24 hours to get a full mix.
    IG Pebbletec Blue Tahoe; Paddock Pool PCC 2000 pop-up; 22,275 gal 32' x 16' Diving with Auto-Fill
    Pentair 420 Cartridge filter; 3 hp VS Whisperflo Main Drain, 1 1/2 hp Whisperflo Running Pop-Ups; Jandy AquaPure 1400
    1 1/2 Whisperflo dedicated to Rock Waterfall; TF-100; Taylor K-1766; Pool Built in 1997
    Aug 2010
    Dallas, TX
    4,052
    Re: Adding Salt
    My SWG is tied to direct AC, but it has its own power switch. Several models do.
    And I follow Xexys's method. I don't dump ANYTHING in my skimmer.
    Apr 2014
    Stony Brook, NY
    159
    Re: Adding Salt
    Uh oh....I added salt last week to my skimmer with swg on. The level read 6000 on the unit till it disapated. Seems to be working OK. Should I be worried??
    14000 gallon 16x32 roman in ground vinyl, Hayward 140k heat pump, swg, de filter 1 1\2 HP v.s. pump. Built in June 2014. Tf100 test kit.
  20. Back To Top    #20
    May 2014
    Mesa, Arizona
    180
    Re: Adding Salt
    I would never add anything directly to the skimmer. I don't think worrying about it would help of course. Just be careful when adding any chemicals to your pool by turning off the SWG first. All of the professional advice of these boards are very good. Use pool math to help you decide your amounts, that calculator is dead on accurate.
