Results 1 to 8 of 8
Thread: Plumbing Layout
    Aug 2010
    Central Illinois
    49
    Plumbing Layout
    O.K., I found a kit I am going to buy.18x36 sport bottom inground vinyl liner. I am planing on starting in early July. My buddy who is doing the excavation work is a farmer.(I have to give him time to plant and what not.)The two ends of the pool are at the north/south and (long)sides are east/west. I am either going with a super pump 1hp or a 2 speed super pump 1hp. I am having two skimmers and 2 step jets. I do not know how many other return jets to have or where to place the skimmers and returns. I am looking for a diagram of a plumbing layout to use, but am having trouble. I am not going to have a heater. I am also going to use 2 " pvc for plumbing unless convinced other wise. I would appreciate any advice and suggestions. Thanks, Dan
    DIY 18x36 Vinyl Liner 1Hp 2 speed super pump, Hayward Swim Clear cartridge filter, Pentair 12v Intellibrite 5G, MX8 suction pool cleaner.
    Re: Plumbing Layout
    I highly recommend the two speed version of the pump. Running on low speed can save you quite a bit of money.
    I don't know of any good diagrams for a basic pool. Most people feel it is so simple that they don't write it down. 2" plumbing is great. Put the skimmers on the sides the wind tends to blow towards. Personally I think two returns are plenty, but the modern trend is to put in lots of returns.
    Aug 2010
    Central Illinois
    49
    Re: Plumbing Layout
    Thanks, Jason O.K. I am going with the 1hp two speed super pump and the C4025 cartridge filter. 2 skimmers, two returns, two main drains and two steps jets. My question is do I run everything in 2" or just the skimmers(separate lines back to pad w/ a three way valve) , returns(also separate line from pad with a three way valve) and the main drain(separate line back to pad w/ a three way valve tied into the three way from the skimmers). And then run the steps jets back with 1.5" from the pad(Two way valve before three way for returns, then single line back to steps and a T by step splitting it)Hope this makes sense to someone else but me. LOL By the way this forum is like an encyclopedia/owners manual/instruction book for pools.
    Re: Plumbing Layout
    That all sounds right. 2" lines back to the pad for everything except low flow things like the step jets. The two main drains share a single 2" line back to the pad. Three way valves so you can select suction source. Either three way valves to select return, or two way valves on each line to control where the water returns to.
    Aug 2010
    Central Illinois
    49
    Re: Plumbing Layout
    What about the steps jets then? Should I just run one 1.5" line from the pad and then T them at the pad. I think I will use the separate two ways on the returns. It seems that I would have more control over water to each of the returns.
    Re: Plumbing Layout
    One 1 1/2 for the step jets should be fine. I would make sure that runs from the T to the individual step jets are the same length and have the same number of 90s, or as close to that as you can manage.
    Aug 2010
    Central Illinois
    49
    Re: Plumbing Layout
    Would this setup work with these valves or do i need something different?
    Re: Plumbing Layout
    That is fine.
