Thread: Ohio Pool Opening
    Apr 2011
    South Point, Ohio
    32
    Ohio Pool Opening
    Hello all first i would like to say this is a wonderful site full of great info and i have followed it for years but this is my first time posting.
    We had a 24' round above ground pool installed two years ago. the first two summers opening running and closing has went flawless using the BBB method learned from here. In mid-February we noticed a hole has formed in the middle of our winter cover after the large amounts of snow and ice we received here in southern Ohio. Needless to say the pool water got a large amount of rain/snow water into the pool water, plus some sun light pass through. The weather is now turning nice here so i decided to take a peak under the cover and see what shape we were in. Needless to say the water was still clear (minor cloudy) with the beginnings of allege growth. With the winter cover still on i went ahead and fired the pump back up and started balancing the water levels. After bring the water up to shock level for 24 hours with running the pump 24 hours the cloudy look is gone but the minor allege growth still appears to be present. Now for my question - would it be wise to go ahead and removed the winter cover and begin sweeping and maintaining the pool like i normally would even though it is two to three weeks earlier than i normally would here in Ohio?
    24' Round Above Ground
    15,000 Gallons
    Hayward Pro Series 100 Lbs Sand Filter
    Hayward Power Flo LX 1hp Pump
    8 gallon Liquidator 3/8
    BBB Method
    Re: Ohio Pool Opening
    Sure, open it up. That will make it simpler to take care of and nicer to look at. The only disadvantage is slightly more chemical usage in the next two weeks.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,374
    As long as the freeze danger is passed you can open any time you want. It will be easier to clean it up now instead of waiting a couple of weeks and trying to clear a potential swamp!
    Love TFP? Become a
    TFP Supporter!
    Apr 2011
    South Point, Ohio
    32
    With the water becoming balanced should the alage disipate after a good sweeping?
    15,000 Gallons
    BBB Method
