Results 1 to 10 of 10
Thread: Found a problem after uncovering pool
    linda1's Avatar
    Mar 2010
    Western Pa.
    298
    After we removed the cover, we noticed if we follow the water line around, it was way off on one side. I'm guessing that the one area of the ground sunk? I also guess there is nothing we can do about this?
    south side
    north side
    30 ft. round Conquest agp, 19,800 gal; Pentair Easy Clean 1 hp DE EC60 filter system
    Hayward H250N gas heater; TF100 Test Kit
    2 Fafco 4x20 sunsaver solar bear solar panels
    Dolphin E 10 ~ Zoomerang slide
    Majestic 8000 Above-Ground Pool Step
    Re: Found a problem after uncovering pool
    The only effective way to fix that is to drain and remove the pool, re-level the ground, and set everything back up again.
    That is pretty far are off level. It looks like it is far enough out that you might be at some risk for part of the wall collapsing.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,621
    How much is it off from the highest to the lowest point and over what distance? My eyes aren't what they used to be and all the reflections of that 'purty water ain't helping either!
    linda1's Avatar
    Mar 2010
    Western Pa.
    298
    Quote Originally Posted by woodyp
    Seems to be 2 1/2 inches.
    The pool was installed last May so this is the first winter it went through.
    Apr 2010
    East Texas
    9,621
    A couple of inches over any amount of distance may not be too bad for that whopper size pool. Have you checked to see if the toprails are reasonably level besides just the water level on the liner being off?
    I'd think you'd be in a lot better shape if the bottom of the pool in that area just sunk some and stretched the liner than if it had pulled the toprails out of level or the posts had sunk as well. Heck I was off almost that much years ago on a 10 ft round pool when my daughter was little and it lasted till she got tired of it. Then I TOOK IT DOWN! It didn't collapse. Don't give up hope just yet!
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,396
    Mine has been like that for about 5 years. I keep an eye on it and it has never gotten worse. The pool is close to the property line and our neighbor had removed a big tree a couple of years before we installed the pool. Looks like one of the big roots ran under that part of the pool and we had a little sinkage after the root decomposed. Walls are perfectly straight.
    Love TFP? Become a
    TFP Supporter!
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Mines like that. Not an issue for me in 10 years... just annoying to me (Pooliosis)
    linda1's Avatar
    Mar 2010
    Western Pa.
    298
    I'm not sure how to check the toprails for level. I walked around and I can see the bottom rail all away around the pool, so it doesn't appear to have changed any. My worrying might be for nothing if the cats shredded the liner. I have a post telling that story.
    frustratedpoolmom, it will bother the heck out of me too.
    Apr 2010
    East Texas
    9,621
    I meant the toprail of the pool. Lay a 2x4 across sections and check it with a level unless you can just eyeball it and tell. Probably not if it isn't very obvious. Sorry about the kitties!~
    linda1's Avatar
    Mar 2010
    Western Pa.
    298
    I took a 4 foot level out and checked in several places around the top rail. Every section was right on. Maybe you are right and the soil sunk under the liner. Now I'm watching to see if the water level drops.
