Thread: Where does all the salt go?
    phalcon51's Avatar
    Oct 2010
    So. California
    203
    I have only a very basic understanding of how an SWCG works and I'd like to understand the process by which the chlorine is generated and what becomes of the remnants of the sodium chloride. As I understand it when regular bleach is used up it is converted into salt. How is the chlorine released from the sodium chloride in the chlorine generator and what is left over when the chlorine is used up? If it turns back into a salt of some sort does the salt content of the water just keep rising over time or is the salt actually consumed or broken down? Are there any long term concerns with buildups of the salt residue in the water? If not, where does it all go?
    Thanks
    Gary
    26,200 gal. 35' x 16' Plaster IGP (50 yrs. old), Hayward 48 sq. ft. DE filter, Hayward EcoStar VS pump, Intellichlor IC-40 SWCG, The Pool Cleaner 4X suction, Pool Skim and Pool Devil skimmers. Re-plastered Sept. 2010.
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    Re: Where does all the salt go?
    Let's see if this post (i-m-confused-t27248.html#p224658) can help with that any of that.
    The super simple answer is that the salt is converted into chlorine by the SWG cell and when the chlorine gets used up it turns back into salt. For the much more technical full story read through the post that Ohm_Boy linked to.
