Thread: no air
    no air
    Hi everyone, I am new here and new to my pool and spa.
    I need some help! I have an inground plaster spa and when I first moved in the jets worked but now just water blows through no air, ary ideas?
    52,000 gal. rectangle 24' x 48' IG gunite, 7' rasied spa, IC60 SWG, VS3050 pump, FNS60 DE filter
    Mar 2011
    Scottsdale, AZ
    406
    Re: no air
    Does it have a seperate blower for the spa?
    If not are there holes in the deck above each spa jet?
    If not look for a probably 2" pvc sticking up, possibly near pool equipment, that doesnt have anything attached to it.
    If you find it try using a vacuum or some other device to blow air into it to clear the air line.
    Do this with the jets on.
    Re: no air
    Thanks I give it a try
