Results 1 to 7 of 7
Thread: triton II sand filter
    still working on try to figure out my filter how do i get the old sand out to put new sand in ?????
    16\32 30,000 gallon inground pool triton II sand filter 3 h.p pump hayward chrlorinator
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,379
    Re: triton II sand filter
    Here is a link to The Triton II filter manual.
    Love TFP? Become a
    TFP Supporter!
    Aug 2007
    near the swamp
    806
    shopvac, hand, dump out
    that still didnt tell me how to get that middle piece out of filter
    how do u put sand in with middle piece in way
    Aug 2007
    near the swamp
    806
    Unscrew or pull straight up, just don't pull out the little air hose. Leave it be.
    The center piece is called the diffuser assembly. You can just push it horizontally to rotate it out of the way. Rotate it back up when you are finished replacing the sand.
    Quote Originally Posted by Pentair
    Pivot the diffuser out of the center of the tank on the TR40, 50, 60, TR60 ClearPro, 100 & 140 by rotating the diffuser assembly counter clockwise. (NOTE: The multi-diffuser assembly should not be moved on models TR100C, TR100C-3 and TR140C, TR140C-3.
    After installing the filter media as described below, check to make sure the tops on the diffusers are parallel to the top of the sand bed.) Fill the tank about half full of water. Pour pea gravel first (if used) and then the sand into the top of the filter at a slow rate so that the impact of the filter media does not damage the laterals.
    Support the site
