Thread: opinion on running plumbing under collar
    Hey guys,
    I was hoping for some opinions....
    I was planning on pouring my concrete ring around my pool walls, then backfilling some and finally running my plumbing so that the pipes were a little higher and less subject to the weight of the backfill. I spoke with a guy today and he suggested that i run the plumbing and pour my concrete ring over the pipes essentially "locking" the pipes into place. He said this is safer and the concrete will support the weight of the backfill and they will be safer encased in the concrete ring. Do you guys think this is safe? it makes pretty good sense to me but I am very new at this. I kind of wish there was only one way of doing this- it would eliminate a lot of my questions lol
    18x36 Kafco steel wall Vinyl liner pool.21,000 Gallons 8ft deep. Pentair 420 cartridge filter, Intelliflow pump, Pentair IC40 salt water generator with Easytouch control system. 2 skimmers, 2 returns
    Re: opinion on running plumbing under collar
    There are slightly fewer problems when the pipes are in the concrete, but really it will work either way.
    solarboy's Avatar
    Aug 2010
    Europe
    337
    I've come across countless pools (usually over 20 years old) where the backfill has sunk and dragged the plumbing down with it breaking unions. This is usually due to poor compacting of the backfill. I usually fit the plumbing to the back of the pool wall with standard pipe brackets, and then chamfer mortar up to the pipes, top and bottom so the pipes in effect become part of the shell. I think you PB is planning this and I'd highly recommend it.
    Self built 5500 gallon bare concrete (temporarily) pool with limestone coping, Pentair Swimmey 1/2 HP pump, Triton sand filter with DE, Simpool peristaltic muriatic acid pump with pH sensor and Monarch SWG. Home made solar heater with Pentair Compool control panel and 3 way valve. 1 skimmer, 1 main drain, 2 returns, 2" plumbing, Hayward auto fill valve.
    Thanks guys....im glad it was brought up to me before I poured the collar!
