Thread: CH is a high
    Mar 2010
    Spring, TX
    1,082
    CH is a high
    I know a good range is from 250-350, but I guess I added a little too much Hardness Plus. My CH level is 425-450. Have a hard time telling the color change. I know at 425 it is a light blue and then one more drop turns it a dark blue. So I assume it is 450. Is this something I need to worry about. I assume it will come down on its on gradually.
    Thanks.
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    Re: CH is a high
    Having CH a little high is not to big of problem, especially if your TA level is normal. If PH TA and CH are all high you will have problems. So keep an eye on PH and TA and make sure they stay in range until your CH level comes down (which will probably be a while).
