Thread: Limited amount of back fill 18'X33'X52" ovel AGP
    When leveling the ground that was 4 inches above the required limit (of one inch) the Bobcat dug down 7" on one side to level the surface. Is there a limit as to how much back fill can be applied without damaging the walls of the pool?
    Thanks!
    25,000 gal. inground
    vinyl liner
    Hayward sand filter
    Circupool SWG
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Limited amount of back fill 18'X33'X52" ovel AGP
    Not sure about this; it likely depends on the specific model of the pool. I doubt seven inches would be a problem, but maybe someone else will stop by and help.
