Results 1 to 7 of 7
Thread: New here
    New here
    Hello! Lots of helpul topics on here. I am in Dallas, have a pool that i didnt pay much attention to for 3 years until I re-plastered last week. Pool service handles all of the maintinance, but now that i have fresh plaster i plan to get involved.
    36k pool with attached raised spa, specs on equipment coming once I take a look! New Plaster Brite white plaster.
    Re: New here
    Welcome to TFP!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: New here
    Welcome.
    If you are going to "get involved," you really need your own test kit. Pool school has a section explaining the tests and what you need. With you living in Texas, I suspect high Calcium will be a concern, so get a speedstir. It makes the CH test bearable.
    The pool service I fired used test strips! Which explains why, when I first tested my water with a proper kit, pH was off the scale, CYA was somewhere around 220-240... So much for hiring a professional!
    Butterfly's Avatar
    South Carolina
    10,045
    Re: New here
    Welcome
    You're done SLAMing when:
    Re: New here
    how do you add a signature? It looks and i read that it is helpful for others to see to know how to adress issues with pool if general stats are known.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: New here
    Quote Originally Posted by Mattindallas
    Oh yes, very helpful!
    Go to User Control Panel (under TFP logo, top left of page), select Profile, then select Edit Signature.
    Feb 2008
    Denton, TX
    5,061
    Re: New here
    Welcome to TFP!
