Thread: Newby here with question or removing and attaching cleaner
    My pool was re-plastered last week, after the initial start up the start up guy re-attached the cleaner. I read not to run the cleaner for 3 weeks or so on new plaster so i want to pull it out. How do I removed the cleaner from the wall fitting? I know i know, silly question but i dont want to break the fitting by twisting and turning it the wrong direction. Thanks!
    36k pool with attached raised spa, specs on equipment coming once I take a look! New Plaster Brite white plaster.
    30,421
    Re: Newby here with question or removing and attaching clean
    What kind of cleaner? Brand and model.
    Letro Legend i beleive, will check it out this evening. Older model, probably 7 years old. I plan to upgrade it shortly. Just didnt know how the disconnect works at the wall fitting
