Results 1 to 7 of 7
Thread: Is this a basketball hoop sleeve? or What?
    Any ideas what this would be?
    It is 4" pvc, cemented into the deck. I cleaned it out and there is a steel rod that sits on the bottom. You can see where it is in relation to my skimmer basket.
    Daren
    12,500 Gal In Ground Plaster, Zodiac lm2-24 SWG, Cartridge Filter, Attached spa, Waterfall, Phoenix AZ
    Re: Is this a basketball hoop sleeve? or What?
    That looks like a sun umbrella pole sleeve.
    I thought that may be it too, but I have 4 other sleeves around the deck that have 1 1/2" threaded tops. This one is 4", seems excessive for an umbrella, no?
    Ft Lauderdale, Florida
    1,455
    Where are the other holes? They may be for play accessories around the pool, depending on where they are. Sometimes these can be used with volleyball net poles, swim exercise poles (think of a fishing rod with a tether on the end that attaches to you), or umbrella poles.
    Sean Assam - Sean@teamhorner.com
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps www.aquacal.com
    AutoPilot Salt Chlorine Generators www.autopilot.com
    There are 2 that look like they could be for a volleyball net, as they are directly across from each other about mid way through the pool, and 2 in the deck by the spa. The fifth one is definitely for an umbrell, its in the floating table.
    That 4 inch sleeve is for a basketball pole. Mine is set up just the same as yours.
    20,000 gallon IG Gunite, Pebble Sheen Blue Granite, PV3 Infloor, All Jandy EQ, 1000 Sqft Adobe deck
    Mar 2011
    Scottsdale, AZ
    406
    Yes a basketball sleeve.
    The metal bolt you see in the bottom is to make contact with the metal pole of the basketball hoop so it is bonded as part of the pool system for safety.
