Thread: leak in Pump Housing Gasket
    Hi folks, I have a leak in the pump housing gasket of a Superpump. A fine stream is shooting out between the pump strainer housing and the seal plate. I have the Seal Change instructions from Hayward. My question is: Do I have to, or should I change out the seal assembly and the diffuser gasket at the same time I replace the pump housing gasket? or should I not worry about these if nothing has gone wrong with them? My pump is about five years old and I use the pool about six months a year. Thanks for any input. Chris
    19,000 vinyl pool, solar heat, .75 hp tristar, 48 sq ft de filter
    Mar 2007
    Coastalish 'down easter'
    4,160
    Chris, in my experience, if you take the motor out of the housing, it's best to replace the shaft seal. If you only have to replace the housing gasket and don't play with the impeller, you may not have to change the seal. However, I'd say that the housing gasket is not the cause of the leak, the seal assembly is! If you care to take the time to open and reopen the pump, you can try to just do the housing gasket.
    Part #s:
    Housing gasket is SP-1600-T
    Seal assembly: SP-1600- C- 1
    If you need any help on doing the change, and I wouldn't trust the Hayward instructions, just ask
    Luv& Luk
    -Ted
    Thanks much. I am trying it tomorrow morning.
    Chris
    Mar 2007
    4,160
    Please let us know how it goes 8)
    BTW - welcome to TFP!!
    Luv& Luk
    -Ted
    I successfully pulled the pump apart and replaced all of the seals. Waste, you were right to replace the seals as well as the housing gasket. there was evidence of a slow leak in the seal. The only problem I encountered was rusted screws on the motor cover. One broke off and, if I get a rattle or vibration, I will have to drill it out and replace. The pump now runs more quietly and with no leaks. Thanks
    Mar 2007
    4,160
    Chris, always glad to help! If by the motor cover, you mean the back 'cap' that protects the electrical stuff - if it starts rattling, just give it a wrap of duct tape and forget the new screw.
    Happy to hear all is better now
    Luv& Luk
    -Ted
