Results 1 to 12 of 12
Thread: Please Help Me Choose an Intex AGP
    lovemy3azboys's Avatar
    Mar 2011
    Phoenix, Arizona
    63
    I've been lurking here collecting info to help me choose an AGP. Because of limited funds we're going with an Intex Ultra & the biggest size we can fit is an 18' x 52".
    Because of what I've read I'd eventually like to add a SWG(althought my husband is afraid it will be too salty) if the work of clorine becomes too much & it sounds like a sand filter would be a good add on down the line.
    Here are my choices as I see them.
    Intex Ultra with 2500gph CARTRIDGE filter
    Intex Ultra with 1500gph SWG, when I called Intex I was told I cant upgrade the filter when it comes as a SWG package so I'd be stuck with this 1500gph
    Intex Ultra with 1600gph SAND Filter
    Can anyone offer any suggestions?
    FYI we live in Phoenix AZ
    25,000 gallon plaster dive pool, Eclipse sand filter, 1 HP Centurion pump, Baracuda G3, TF-100 Test Kit
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: Please Help Me Choose an Intex AGP
    If those were my 3 choices, I would stick with the sand option and you could always add the intex swg on later. Crookm11 has the intex/sand filter and seems to be pretty happy with it. IMO, intex cartridge filters are a pain to deal with when preblems arise vs. being able to backwash a sand filter...but that's just my opinion FWIW.
    Here is a neat little thread he compiled a few days ago, that might be of interest to you
    useful-links-for-fellow-intex-pool-owners-t29612.html
    crookm11's Avatar
    Jun 2010
    Copperas Cove, Texas
    422
    Welcome to TFP!
    As dmanb2b has said I do like my Intex sand filter. As with you I'm limited on my funds. I had the cart filters and they are a pain in the you know what when it comes to clearing a pool with algea and the pumps are not up to par for the task.
    Sand filters IMO are the way to go weather you have the Intex model or other brand. Intex makes two different size sand filter/pump combos. The 1600 GPH Sand filter (14") you have listed is the smaller filter and pump. I would get the 2100 GPH sand filter (19"). Hope this helps.
    Mark Crook
    13,500 Gallon 24' x 52" Intex Ultra Frame
    Intex Sand Filter and Pump, Intex SWG (All hard PVC plumbed)
    TFTestKit-100---Pool School---The Pool Calculator
    Location: Copperas Cove, Texas --- My Pool Build---Useful Links for Intex Pool Owners
    Mar 2011
    Phoenix, Arizona
    63
    Thanks for the welcome & for the answers.
    crookm11, a few questions if you don't mind. My husband wants to know if that's a separate timer at the bottom of the photo. Also, were you able to buy the pool with the 2100gph sand filter or did you upgrade from the original? What size SWG do you have & what in addition do you have to add to your pool besides the stabilizer(to keep the clorine, right?)
    I'm going to call Intex today to make sure if we bought the Ultra that comes with the 1500gph(local so no shipping charges) could we add the 2100gph sand filter without retrofitting.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Upgrade now. trust me if you are going to go that big on the gallons/size do not try to get by with anything less.
    On the SWG - you won't taste the salt. Worth it in the long run. disconnect the copper ionizer portion found on the new units. I think I read on here that saltwater in the ocean is like 30,000 ppm and in the pool its only about 3,000 and you won't taste it. I've swam in swg pools and do not taste salt. water feels great, but I don't know if that's just the power of suggestion or not lol
    mcoonan's Avatar
    Aug 2008
    Mendota Heights, MN
    292
    Try looking online (craigslist, ebay...) for a lightly used pump/filter. I got mine off of Ebay, it is a "real" pump and filter. A little large on the motor, but the filter is great. I really prefer the real cartridge filter, (not the intex ones, they are junk) I swap mine out every month, takes about a 15-20 min to clean. I am adding the SWG this summer, makes maintence that much simpler.
    Intex Ultra 18' x 52" AG 6,981 Gal.
    3 - 2'x20' solar panels
    Hayward XStream 1500 Cart Filter
    Hayward 1-1/2 HP 2-speed Superpump
    Aquabot Pool Rover
    2-Softub 300 hot tubs (yup just got one for the lake)
    TF Test Kit Doing the BBB for 7 years
    Medota Heights,Minnesota
    Dayton, Ohio
    79
    I have an Intex Ultra Frame 16 x 48 that came with an Intex 1500 pump. After doing a lot of research I knew upgrading to a larger pump was a must. (bought an Intex 2500 pump on Amazon for $100 and sold the 1500--didn't even open it up-- for $65). It made all the difference.
    I had a trouble free season thanks to this site. Used the BBB method. Vacuumed once a week on a normal basis, more often when the pollen was heavy as I live in Ohio.
    The only change I am making this year is going with the Unicel cartridge instead of Intex cartridges (I got 10 for $10 last year on craigslist.)
    As for the Intex pool itself, I discovered a small hole when I filled it, but the patch kit that came with the pool did the trick. It is a great pool if you do not or cannot invest money into a more permanent pool. The take down was INCREDIBLY easy, too.
    Good luck!
    AG Intex Ultra Frame
    Round 16 ft x 48 in, 5061 gal
    2500 gph Intex Krystal Clear Cartridge Filter
    BBB
    Actually, you can reassure your husband that the pool would not be too salty. In fact, the salt water chlorinator has less salt than a tear drop (The salt in human tears is at 0.9% while the chlorinator is at 0.3%).
    You do need a pump of 1500 gal/hr or greater - however, there are several combined units including the brand new 2650 gal/hr sand filter/saltwater chlorinator combo for about $500. Clearly there are more options, but I just wanted to give you a ballpark to work with. The benefit to using sand versus traditional filter cartridges is that within the first summer the sand will pay for itself with the savings - as you move towards the end of the summer you will endure higher costs as the need for filter cartridges increases, and as you need more to continue to keep your pool clean.
    I hope this helps, have a great day!
    Customer Service Representative
    Coolinflatables.com
    crookm11's Avatar
    Jun 2010
    422
    Quote Originally Posted by lovemy3azboys
    Hello,
    I'm not sure what you mean by separate timer? If you are refering to the SWG then yes the SWG has a separate timer from the pump. The pool did not come with the sand filter in the picture. I had to buy it separately. The new sand filter/pump does come with the SWG included with the pump but it will have the copper added to the unit. The SWG in the picture is the pre-2010 model with out the copper. I also have an extra one as a backup for when this unit goes bad. The sand filter in the picture will have no problems being added to your pool. No modifications will be neeeded.
    Mark Crook
    lovemy3azboys: Anything 1500 gal/hr pump and higher comes with an automatic timer - sand filter pump, filter cartridge pump as well as the combination pumps. Free shipping is also standard with a lot of pool suppliers, go ahead and google my username and use promotion code - discount10% - to help you save even more.
    If you added the sand filter you would NOT have to retrofit, as they both utilize the 1.5" diameter inlet/outlet holes in a pool of that size. It's the smaller pools with 1.25" holes that have to retrofit.
    The SWG only comes in one dynamic, there aren't different sizes. The sizes only matter with the actual filter pump. If you have any other questions I could easily help you out with any of these as I do work with these pools monday through friday.
    Happy shopping! - Cool Inflatables
    Coolinflatables.com
    Mar 2011
    Phoenix, Arizona
    63
    Thank you to everyone who responded. So thankful to have found this site, otherwise I'm guessing I'd have to learn the hard way, yikes!
    I believe my husband thought the SWG was a timer itself. Thanks for the clarification.
    Why dont I want the copper in the newer unit? I've seen it mentioned but havent run across why people dont like it.
    Thanks for your answers
    11,969
    Copper can cause staining in some cases on some pool surfaces. It causes blonde/white hair to turn green. Just isn't necessary so we recommend disconnecting that part.
