Thread: Pool LED light question
    Jul 2010
    Montreal, Canada
    49
    Hi guys,
    before opening my pool for the first time I was thinking of installing a pool light
    This is the model I'm looking at;
    http://www.costco.ca/Browse/Product.asp ... =C&topnav=
    do any of you have experience with a thru wall light? I was looking at this model because I dont have to make any new holes
    I was looking at my existing return line fitting, and it is screwed pretty tight, not sur if I should force it to unscrew,
    would the existing fitting normally unscrew or is it something the installers would have glued?
    Thanks
    18 feet AGP
    SWG
    Catridge
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Pool LED light question
    Seems pretty pricey for what it does, but maybe someone else will stop by.
    Jun 2010
    South Alabama
    38
    If you have a intex pool you can get intex thru wall light for about 50 dollars..So you can buy 2 for the price of that one and they do really good..
    18' x 4' intex pool, 7600 gallons, 2500 GPH intex pump with sand filter...
    Jul 2010
    Montreal, Canada
    49
    I dont have the intex pool,
    I do like their thru wall magnet light, but I think it would work on my pool, i think its specifically for intex pools
    eventhough the light is pricey I cant seem to find anything else, I dont want the ones that float and use batteries
    do you guys have any ideas
    also do you think the light in the link on my original post can be easily installed
    thanks
    18 feet AGP
    SWG
    Catridge
