Thread: Solar Cover Utilization
    Mar 2010
    Ridgeway, SC
    25
    Just opened up the pool.... removed the mesh cover, cleaned up water, balanced chemicals, cleaned filter, pressure washed the deck - all systems are "Go!" Water temp at 60 degrees F (Yes, I got in. Yes, it is COLD!). Weather highs/lows for next several days mid-70s/mid-50s. Should I leave the solar cover on, or should I be taking it off in the mornings and replacing in the evenings? Thanks!
    17,000 gal fiberglass. 1.5hp pump, Pentair 60 sf DE filter and Pentair IC-20 SWG, TF Test Kit, BBB
    22,551
    Re: Solar Cover Utilization
    What color is your cover? Mine's clear and I leave it on all the time but a colored cover that reflects the sun should be removed when the sun is shining and replaced when it's not.
    Mar 2010
    Ridgeway, SC
    25
    The cover is clear.... Thanks!
