Thread: Salt level and SWCG efficiency
    Sep 2010
    SC Lowcountry
    54
    I was curious if there was any info regarding salt levels and their effect on SWCG output percentages and their efficiency. Specifically, if I was to bump my salt level up slightly, would I still be able to maintain my chlorine levels at the same amount of pump run time but at a lower chlorinator output percentage?
    Viking Laguna 14K IG , Smart Pure SWCG, SwimClear C5520 Cartridge Filter, TriStar 1.5HP, SmartControl PLP4 controller.
    Re: Salt level and SWCG efficiency
    That depends on which brand/model of SWG you have. Some of them compensate for the salt level and always produce the same amount of chlorine, while others vary their output depending on the salt level. Even if yours is one of the ones that varies, the change won't be all that large as the unit will stop working if you raise the salt level too much.
    Sep 2010
    SC Lowcountry
    54
    I was just wondering about cell output at different salt levels and it's possible effect on cell life. My wife accuses me of thinking too much. She's probably right.
    Cell life in essentially a constant amount of chlorine produced, regardless of the rate at which that chlorine is produced. In more technical terms, cell life is measured in amp/hours, which is directly proportional to the amount of chlorine produced. So it doesn't matter what the salt level is (as long as the cell is working).
    Jul 2007
    Brisbane, Australia
    874
    with higher salt levels you can achieve the same chlorine output and/or amps with lower voltage applied, which benefits both power supply and cell and also reduces your energy consumption.
    Some units can work up to sea water salt levels (examples would be some Autochlor models, and Autopilot I believe)
