Thread: muriatic acid w less fumes
    Mar 2009
    Charlotte, NC
    539
    Saw a muriatic acid that claimed less fumes (& a scent I think?) etc.
    Is it ok?
    I know scented bleach is NOT what we want.
    Thank you.
    19,800 gallons (closed/winter 18,654 gal); plaster; 18x34 Ft kidney bean shape, Depth 3Ft-5Ft. Built 1992
    Pentair Whisper Flow Pump 1HP. Winter safety cover w anchors.
    Sand filter, Pentair Sand Dollar Top Mount Model SD80; Effective Filtration Area 3.5SF
    - FlowRate 75GPM, 8Hr 36,000, 10Hr 45,000, 12Hr 54,000; Pressure Weight 50PSI
    BBB (Hayward Chlorinator when leave town). Polaris 360 cleaner.
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: muriatic acid w less fumes
    You can just buy half-strength Muriatic Acid which is 15% Hydrochloric Acid (instead of 31.45%) as this fumes a lot less. If you can't find any, you can make your own 50/50 diluting with distilled water (wear goggles to protect your eyes). Just remember that "if you're doing what you 'oughta, always add acid to the water". Never add water to concentrated acid as it can splatter from the heat of dilution.
    I wouldn't use acid that has perfumes in it.
    It's listed as safe for use in pools, but I only use it for cleaning. Since it has an extra ingredient, I choose not to use it for pH control.
    chem geek, the acid contains special buffers that greatly reduce fumes. It does not contain any type of scent.
    http://www.wmbarr.com/product.aspx?catid=99&prodid=206
    http://www.certol.com/AcidMagicHome.aspx
    Support the site
    Mar 2007
    San Rafael, CA USA
    12,082
    Oh, you're talking about Acid Magic. We've looked into that before. I only commented on the perfumes because of the original post that thought it might have that in it. Acid Magic seems to be mostly Muriatic Acid (possibly in the 15-20% range if one goes by the "< 25%" in the Klean-StripĀ® Safer Muriatic Acid product), but probably has some organic acid in it as well to make up the difference. Generally we don't want to add extra things like unknown organics to the pool.
