Thread: No flow switch problem
    I just installed a new Goldline flow switch and the No flow light is still blinking. I have checked the arrow directions and I don't know where to go from here. Can anyone give me any ideas? I have an Aqua Rite Goldline SWG.
    Thanks
    Robert
    22,553
    Re: No flow switch problem
    Welcome to TFP.
    Did you jumper across the flow switch terminals to make sure the switch was the problem?
    Re: No flow switch problem ( continued)
    Hey Dave, I took the old switch and installed it into the opening on the turbo flow then I took the end of the new switch which is like a telephone wire and
    put it into the bottom of the control panel and the light on the panel went out. as per instructed by the tech at goldline. thanks again robert
    Malibu07's Avatar
    Jun 2010
    Southeast VA
    207
    My LED light was blinking saying "No Flow" today too. I checked to make sure that the plug was secured and inspected the wire. All seemed fine, so I cut the SWG off for about an hour with the pump still running. When I turned it back on, the blinking light stopped. So far so good!
    14,700 gal. 14 x 28 rectangle with 2R IG by Hydra Pools, 1 hp Hayward Maxflow ll, Hayward 24" Sand Filter, Aquarite Electronic SWG, one Aqua Genie Complete Skimmer, two main drains, four returns, 2 spa jets in steps, 30ml Tidewater liner. Taylor K-2006 Test Kit
    22,553
    Take a few pictures of your setup and let us look at it.
    Is the return flow about the same as always?
