Results 1 to 7 of 7
Thread: Anyone tried the copilot systems with ozone??
    Apr 2011
    W.Sussex, UK
    29
    Hi,
    Looking for a swg system to convert my pool....
    I was wondering if anyone had tried the copilot system with the autopilot SWG and the ozone system??
    Can anyone point me in the right direction, avdvantages/disadvantages of using ozone system??
    James
    New to pools...
    Approx 13,200 gallon pool - 24ft by 14ft by 4.5ft
    Larcon Filter with Durafiler Glass media (instead of sand)
    3/4hp Pump, 17k Heat pump, IG Vinyl pool, with Oase roller Solar cover
    Re: Anyone tried the copilot systems with ozone??
    Ozone is generally not worth using in a residential outdoor pool. Ozone is very efficient at breaking down CC, but chlorine plus sunlight is plenty good enough if you only have a couple of people swimming each day. Ozone becomes much more worthwhile when you have a high bather load, such as in a public pool. Chlorine and sunlight alone can't keep up with the CC from dozens of people swimming, while ozone can.
    Apr 2011
    W.Sussex, UK
    29
    Are their any disadvantages with using the two systems together do you think it is just not needed for a small residential pool... The pool will be covered 99% of the time due to having kids around so the UV exposure be much lower. The cover is a roller polycarbonate type.
    New to pools...
    They work just fine together, and CoPilot is a good brand. It just isn't worth the money in a residential pool as the SWG alone works so well at lower numbers of bathers that there is nothing for the ozone to improve on.
    You will want to uncover the pool at least one hour a week or you are likely to have problems (with or without ozone). Keeping the cover on all of the time essentially converts the pool to an indoor pool, which is a much more temperamental beast than an outdoor pool.
    Apr 2011
    W.Sussex, UK
    29
    ok - thats good to know... I would think 1hr a week will be no problem at all.... Is this for UV or can it be at night??
    New to pools...
    There are two primary issues: UV and outgassing. There are several processes that either don't occur or occur much more slowly without UV. Typically only a small amount of UV is required to process the backlog. Meanwhile, various volatile compounds buildup in the water. Given an opportunity they will outgas into the atmosphere. If they build up in the water to high enough levels various complications can ensue.
    Apr 2011
    W.Sussex, UK
    29
    Many thanks for the info!
    New to pools...
