Thread: I'm thinking about a diffrent system to heat pool
    I only have 4 months out of the year when the water is too cold to enjoy.I can't really afford to install and operate a conventional heater so.....I was thinking.
    Along the lines of radiant floor heat where tubing is zigzagged under the floor of a house and hot water from a boiler is circulated through to keep the room comfortable.
    I thought maybe I could do something similar using irrigation tubing..buried about 6" under the soil....maybe just left in a coil....or fanning the tubing out like pushing on a slinky....bury it and let the constant warmth of the sun heat the water in the tubing.I'd set up a bypass valve so I could stop that water from circulating when the water is already warm enough.
    Now I just have to figure out a wayto cool the water in the heat of summer here in southwest florida without having to continuosly freeze water jugs and toss them in when pool water is over 85.
    11000 gal L shaped gunite pool with and aggragate plaster
    Pentair cartridge filtration with 1.5 hp pump
    only have 3 returns and one dedicated vacuum line
    manifold to pump is three valve
    Dec 2009
    Central Massachusetts
    2,690
    Re: I'm thinking about a diffrent system to heat pool
    You would never get enough heat transfer to raise the temperature much at all. To raise 9000 gallons of water 10 degrees, it will take nearly 750,000 BTU. You wouldnt get a tenth that much, if that, using any sort of radiant heat like you described. In your area, solar heat might be a good option. It costs a bit for the initial install, but after that the operational cost is minimal.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    Solar panels can both heat and cool. If you run them during the day they heat and if you run them at night they cool.
