Thread: Test Results after partial drain
    Hark's Avatar
    Mar 2011
    Phoenix, AZ
    24
    I did a partial drain couple of days ago because my CYA had to have been way over 100.
    Have my TF100 on order and have not received it yet but here are the results from taking a sample to Leslie's.
    FAC 4.0
    TAC 4.0
    pH 7.8
    TA 100
    TDS 900
    CYA 80
    Phosphates 100
    Pretty windy here in AZ today so there is an accumulation of leaves but other than that the water looks pretty clear. What do you think?
    First time they did not try to sell me PhoseFree.
    10,000gallon, IG Pebble Tec, Pentair Intelliflo VS+SVRS 3hp Variable Speed Pump
    Hayward Cart Filter C4025, Hayward Pool Vac Ultra, 1 vac line, 1 skimmer, 2 Main Drain, 3 returns, 2" plumbing
    TF100 Test Kit.
    benavidescj's Avatar
    Apr 2010
    Fleming Island, FL
    431
    Re: Test Results after partial drain
    Numbers look pretty good. I assume you are manually dosing with chlorine?? If that is the case you want to keep you FC level above 6ppm (shoot for 9ppm) due to your CYA level being a little high still. Forget the phosphates and TDS readings, they do not need to be tested. At some point you should try to bring that CYA down closer to 50.
    Carlos
    Pool: 28,000 gallons IG; IC 40 SWG; Pentair 120 gpm cartridge filter; Marble finish; Pentair Wisperflow 1.5 hp; Polaris 360
    Spa: 350 gallon; Bromine
    How to shock your pool
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,379
    You need a CH (calcium) test. You are in an area known for hard water and your TA and pH may be a little high if you CH is also high.
    Love TFP? Become a
    TFP Supporter!
    Butterfly's Avatar
    South Carolina
    10,045
    You have gotten good info thus far.
    Well, a CYA of 80 does seem a little high.......unless you are in an area like Arizona and many of your neighbors run a higher CYA (than our normal recommendation) because of the intense heat and sun!
    If your water is clear and has no chlorine loss issues, you may just want to keep it where it is and maintain the appropriate FC level.
    I'm waiting for the TF100 test numbers and then, as Paul Harvey said, we'll hear the "rest of the story"
    You're done SLAMing when:
    Hark's Avatar
    Mar 2011
    Phoenix, AZ
    24
    Got my TF100 and gave it a try tonight. Here are the results:
    FC 1
    CC .5
    TC 1.5
    ph 7.8
    TA 120
    CH 1300
    CYA 80
    Chlorine is clearly low.
    TF100 Test Kit.
    Jul 2009
    Houston, Texas
    9,379
    Please double check your CH result, and test your fill water also. If it is truly that high then you will either need to drain and replace water or get a reverse osmosis treatment to bring the CH down.
    Love TFP? Become a
    TFP Supporter!
