Thread: Wiring a SWG with a 3 circuit timer
    kcjonz's Avatar
    Mar 2010
    Charlotte, NC
    26
    I have a 2 speed pump and was given an Intermatic PE153 from a friend that I have hooked up yet. I am going to be adding a SWG soon (AquaRtie w/ T-15). I need some input on wiring these things together.
    Here is the info about the timer http://www.poolandspacontrols.com/~/...ons/PE153.ashx
    I was thinking of running the timer in Mode 4. (High Pump, Low Pump, Cleaner Pump)
    Having the pump obviously 1 = High 2 = Low and then the SWG on 3.
    Using the timer in this mode will ensure the SWG is never on unless the pump has been running at least one minute per the manual.
    I then found this post http://www.troublefreepool.com/whisp...ml?hilit=pe153
    And deducted I need to wire as follows.
    Power comes in on 1 & 2.
    Common of motor goes to 1 with power in.
    High speed wire on motor goes to 4.
    Low speed wire on motor goes to 6.
    SWG Common goes to 1 with power in
    SWG load goes to 8
    A jumper goes from 2 to 3.
    A jumper goes from 3 to 5.
    A jumper goes from 5 to 7
    Any one out there that know more about electricity confirm this and does the Hayward Aquarite run on 240V so this will all wire together?
    So for the rambling Thanks in advance.
    ____________________________________________
    18 x 36 IG Vinyl (28,000 G), AquaRite Goldline T15 SWG, Intermatic PE153, 1/6 - 1 HP Pump, Triton Sand Filter, TigerShark QC
    Ft Lauderdale, Florida
    1,455
    Re: Wiring a SWG with a 3 circuit timer
    Typically, a two speed pump with cleaner pump connection will have the cleaner pump circuit only come on when the high speed pump is running, for protection of the system. Low speeds usually doesn't provide enough flow for the cleaner pump to draw from, thus the interlock with high speed mode.
    Aquarite does come from the factory wired for 240 volts, unless specifically ordered for 110 volts.
    Just make sure you're running the pump in high speed long enough to ensure you generate enough chlorine.
    The alternatives are
    1) wire the Aquarite on low speed, as long as the low speed is sufficient to activate the flow switch, because the low speed is usually running long enough to ensure sufficient chlorine production.
    2) wire the Aquarite to 1 and 2, in which it will be powered all the time and generating when the flow switch detects sufficient flow, in both high and low speed. However, you're strictly relying on the flow switch to provide protection when the pump shuts off... (NOT RECOMMENDED)
    Sean Assam - Sean@teamhorner.com
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps www.aquacal.com
    AutoPilot Salt Chlorine Generators www.autopilot.com
    kcjonz's Avatar
    Mar 2010
    Charlotte, NC
    26
    Or should I just wire the SWG as an accessory then I can have it switch on or off via timer with the low or high speed on the pump?
    Both approaches work. If you don't mind using up the third timer channel, using that is probably best.
