Thread: Scum Line
    rwrogers11's Avatar
    Apr 2011
    Katy, Tx
    66
    Scum Line
    What's the best way to clean the scum line once I drain the hot tub, what cleaner works best. Also, while full and running, what should I be putting in to help prevent the scum line. I'm currently running bromine, and shocking once a week.
    Richard
    Pool - 18' Doughboy Above Ground Vinyl, 7600 Gallons, 1HP Hayward Power-Flo Matrix pump, Hayward Star Clear Cartridge Filter C500 50 GPM flow rate, Hasa Chlorine Injector, Pool Rover Vacuum, Taylor K-2005 Testkit - Hot Tub - Artesian Pelican Bay, 550 Gallons, Ozone, Nature 2 Mineral Sanatizer, Bromine floater.
    South Central NJ
    3,192
    Re: Scum Line
    If it's stuck on gook, not calcium, a Mr Clean's Magic Eraser works well usually. Terry cloth rags and Spray-Nine also works well. Just remember to rinse it after.
    Scott
    Owner of - PoolGuyNJ LLC
    Jun 2007
    Bradenton, FL
    27
    Re: Scum Line
    Every water change, I always used a citrus based cleaner to clean it down to just past the water line. Stubborn stuff might need a magic eraser, like poolguy mentioned. After cleaning, I'd rinse it all down and wax (with hot tub wax) the tub down to just below the water line as well. The wax really kept junk from sticking too much between changes. The cleaner and wax I used were Leisure Time brand because that's what the local store carried. I imagine there are plenty of options out there. Just make sure whatever it is, it's safe to be using in a hot tub. Because,try as you might, you won't get it all rinsed and drained out... Don't want to be bathing in stuff that will hurt you!
    Also, they make foam floaters that float on the surface and catch some of the gunk that eventually finds it's way to the sides. You just take them out and rinse occasionally.
    Author of The Pool Tool for Windows Phone 7.
    8,600gal PebbleTec, Pentair 2hp, Cartridge Filter, Solar Heat. Hopefully SWG Soon!
    Old -- 22,600gal Vinyl Inground, Hayward 1.5hp, 350# Sand Filter w/ZeoBrite, Color Logic, Aqua Rite SWG. Computer geek.
