Thread: Heated water flow
    Mar 2010
    Houston
    37
    Heated water flow
    I have bottom jets and side jets on my pool...does it matter or make a difference which ones I run heated water to for optimal efficiency?
    Houston
    ~20,000 inground plaster pool
    1.5 HP Hayward
    Sand Filter
    22,553
    Re: Heated water flow
    It shouldn't matter very much at all. The water should get thouroughly mixed and there should be no temperature clines so whether you put it in the bottom or sides should matter.
