Thread: Reality check. Good system choice or not?
    Oct 2010
    Eastern TN
    172
    Just checking. I am planning on a 5400 gallon fiberglass pool. My choices:
    Pentair Intelliflo VS350
    Clean and Clear Plus 320 sq. ft
    EasyTouch 4PSC-IC20
    Does this look like the optimal combo? I will have basic pool, water feature, and will be using a robotic cleaner that does not rely on line pressure. Do you have any suggestions or is the a high quality choice for my application?
    Plaster pool inground 22,000 gallons with spa. Pentair Intelliflo, IC40 salt generator, WiFi control/Easy Touch.
    Hayward 1.5 HP pump on 750 gallon spa. Sand filters. Auto chlorinator on spa. Auto water level. Dolphin M500. TF100 XL with Speed Stir. Apera Instruments AI311 PH60 Premium Waterproof pH Pocket Tester
    Re: Reality check. Good system choice or not?
    That is a nice setup. Depending on what your water feature is, and how high your electric rates are, the IntelliFlo might be a little much, or it might be just the thing.
    South Central NJ
    3,192
    Upgrade the pool to 2" plumbing and that will be a fine system.
    Scott
    Owner of - PoolGuyNJ LLC
    Oct 2010
    Eastern TN
    172
    2" plumbing planned. Looking forward to project start....
