Thread: E-Command Pool Management
    Mar 2010
    Houston
    37
    I'm looking at upgrading to pool to automation management from the manual sundials. The pool builder has recommended the E-Command system with the 6 button remote.
    Does anyone have any experiences with this? Is there any reason to get a ProLogic with the AquaPod?
    I will be running pool only with heater, 2 values to 3 outputs (side jets, bottom jets and waterfall) and a 2-speed pump.
    Thanks for your input.
    Houston
    ~20,000 inground plaster pool
    1.5 HP Hayward
    Sand Filter
    Re: E-Command Pool Management
    The E-Command is a fine choice. The one thing to keep in mind is that most people end up wanting more relays, and often it is more cost effective to get them up front. But if all you need to control are the items you listed then the E-Command will be just fine.
    Mar 2010
    Houston
    37
    What others items would I want/need to control that I'm not thinking of?
    My lights are on a dimmer switch by the house and not near the pool equipment pad, so I don't see myself trying to control those via the remote. Anything else?
    Houston
    1.5 HP Hayward
    Sand Filter
    Possible things you might want to control in the future include an underwater light, landscaping lights, sprinkler system, pool cleaner, etc.
