Results 1 to 10 of 10
Thread: First test results from TF-100
    Hi everyone, I just got my TF-100xl today here are my results
    TA = 70
    CH = 280
    FC = 3.5
    CC = .5
    CYA = 0 was at 50 a year ago pool has a leak
    ph = 7.6 with old test kit (fresh drops)
    ph = with new taylor looked higher and had trouble reading
    Pool is in Palm Beach Gardens, Florida (south Fl). water is pretty clear, I'm beginning to get an algae bloom.
    It's a Marcite pool and it's 15,000 gallons (give or take 5,000 gallons, seriously I have no clue). 1/2 gallon of 10.5 % chlorine added 3.5ppm. Pool calculator can tell me my gallons i think so I'll check there.
    This is my first post, but I've been lurking on this site for awhile so I know a lot about BBB from reading the forum.
    I found some old trichlor pucks 10 years old at least factory sealed and have been using them when I run out of chlorine. I thought I would have at least some CYA even with the leak.
    Your advice is greatly appreciated!
    Sharkline Dolphin AGP 24" x 54" Millennium cartridge filter Millennium 2-way 2HP-3/4HP pump
    Jan 2010
    Central Valley, CA
    233
    Re: First test results from TF-100
    I'd bump the chlorine up to shock level. Can't hurt and sooner you do it the better.
    Garden Leisure Voyager 12x24 AGP, 7500 Gallons, Hayward Power Flo Matrix 1 HP pump, dual speed, Hayward XStream Cartridge Filter, 120 GPM,
    30,403
    Welcome to the forum
    I would suggest you bring the FC up to 10ppm immediately. However, what the algae doesn't consume, the sun will get within 24 hours. Nevertheless, you need to get a good, algae-killing dose of chlorine in there right away.
    Next, (forget the pucks) put in enough granulated CYA to get to 40-50ppm. Withing 24 hours of introducing the CYA, go ahead and shock the pool properly (be sure to read how in Pool School) by bringing up and holding the FC to around 16-20 until your pool is perfectly clear.
    You likely have more algae than you realize so don't be surprised if it takes several days to get your pool crystal clear.
    Welcome to TFP!
    You need to get the CYA level up to something reasonable. I suggest raising CYA up to around 30 very soon, and probably higher after the algae is dealt with.
    While your CYA is very low, you don't need all that much chlorine to shock. Raising FC up to around 10 to 12 in the early evening, and if possible do that again in the late evening, is the best you can probably do until you get more CYA in the water. With CYA very low, you lose too much chlorine during the day to be able to shock effectively.
    Similar to what duraleigh said.
    ThePoolNinja's Avatar
    Apr 2011
    Southern California
    61
    I like to keep my TA between 100-120 usually.
    Quote Originally Posted by ThePoolNinja
    Which is a wonderful idea if you are using trichlor tablets for chlorine. But 2020true said they were using liquid chlorine, for which we recommend TA between 70 and 90.
    22,543
    Welcome to TFP.
    I wouldn't adjust anything except raising the FC up to 10 as suggested. From the calculations your pool should be about 13,500 gallons, so your original estimate wasn't too far off.
    How bad is your leak?
    Do you have an autofill?
    Thanks for all your help everyone
    I'm going to buy CYA on saturday (put it in a sock in the skimmer or in front of a return) The powder form is cheaper correct?
    It takes a week to register on the test, but once it's dissolved it is in there working, right? (so I can adjust my shock level)
    Should I run the pump 24/7 until it dissolves?
    Are there CYA brands to avoid? Should I buy it at Walmart or pool store?
    I will shock to 10 ppm tonight add more in the morning before work. I don't work Sunday or Monday so I'll have time to do it right.
    No autofill but we add water around two hours a week from garden hose.
    By the way I got pool-stored today. Guy tells me Cal-hypo lasts longer in the pool than sodium hypochlorite. I didn't have the heart to tell him that once it's in there it's all the same thing, chlorine.
    Thanks again for all your replies
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,377
    Quote Originally Posted by 2020true
    Yes powder is cheaper than liquid. Even though it does not register on a test right away, go ahead and act as if it did when dosing the pool. You don't need to run the pump 24/7 just for the CYA. Just let it soak in the sock and give it a good massage a couple of times a day until it has all dissolved. Run the filter as normal. You can uses the HTH brand Wallyworld sells or you can get it from the pool store. Just check the active ingredients. As long as there is not a bunch of junk mixed in with it, it should be fine.
    Pool store guy was half right. The hypo lasts a few days at best. The cal lasts forever!
    Love TFP? Become a
    TFP Supporter!
    thanks going to get some cya now
