Results 1 to 7 of 7
Thread: Waste valve
    Cedar Island NC (Outer Banks)
    84
    Waste valve
    Not sure what to call this so maybe that's why I can't find anything in a search.
    My Hayward filter lets water run out of the waste hose even when it is in the normal mode. It does not come out with any pressure but it will still flow even if the end of the waste hose is above the water line. In fact, I have tied it off so that it dumps the water in the pool rather on the ground.
    Is this common/easy to fix? Thanks in advance. Steve
    Cedar Island NC (Southern Outer Banks)
    Splash Super Pool (40x20)
    29,000 gal; AG; Sand Filter; 1.5HP pump. Use the cosmic Taylor Test Kit
    New Aquarite SWG w/T-15 cell; New Dolphin Supreme M4 Robot cleaner
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,818
    Re: Waste valve
    Sounds like you might be in need of another multiport valve spider gasket.
    Oct 2010
    Georgia
    317
    Re: Waste valve
    Steve
    The page below has a picture of a Hayward sand filter with a multi-port valve.
    There is also a picture of the "spider gasket" that woodyp is referring to.
    pool-school/visual_encyclopedia
    Post the model number of your multi-port valve.
    poolschoolgrad
    20x40 free-form IG vinyl, 1hp Hayward superpump, Hayward pro grid DE filter, Raypak heatpump, Goldline Aquarite SWCG, Polaris 280 with booster, and tested using a Taylor K2006.
    84
    Re: Waste valve
    Ahhh, that's what a spider is. My valve is a SP 714 TX, Hayward Vari Flo XL. Thanks!
    Oct 2010
    Georgia
    317
    Re: Waste valve
    For the SP 714 TX Vari Flo valve, the spider gasket is only available glued to the diverter.
    It is called a Key seal assembly or Diffuser with gasket glued in.
    part # SPX0714CA
    It is around $35.
    poolschoolgrad
    84
    Re: Waste valve
    Quote Originally Posted by Poolschoolgrad
    It is called a Key seal assembly or Diffuser with gasket glued in. part # SPX0714CA It is around $35.
    Thanks much! presume it is an easy replacement.
    Oct 2010
    Georgia
    317
    Re: Waste valve
    You can do it
    poolschoolgrad
