Results 1 to 12 of 12
Thread: Difference between Pentair 261049 and 261050?
    Mar 2011
    Central Florida
    69
    This will be going on a Quad DE 60 w/ Hayward EcoStar pump. The manual for the Quad DE says 261050, but I think the one that poolsupplyworld has in the "DE Kit" is 261049. What is the difference between these two?
    261049 Pentair HiFlow 2"
    261050 Pentair Pac Fab HiFlow WG
    8,700 gallon IG pool (including 2000 gallon spill-over spa), WetEdge Northshore Tahoe (Satin Matrix) finish, Hayward SwimPure Plus T-15, Jandy JXi 260k propane heater, Jandy FloPro 1.5HP 2 speed pump, Jandy CS 150 cartridge filter, TF-100, Borates added, BBB is the way for me!
    22,543
    Re: Difference between Pentair 261049 and 261050?
    Looks like the 050 has the plumbing on it for the side mount filters and the 049 doesn't.
    Mar 2011
    Central Florida
    69
    I thought it was the 261055 and 261142 that had the side plumbing?
    http://www.poolsupplyworld.com/poolsupp ... valves.htm
    22,543
    Well, you've got me there! The place I looked showed the 050 with the plumbing and the 049 without!
    Mar 2011
    Central Florida
    69
    Weird, huh?
    South Central NJ
    3,192
    261142 is for the FNS series of filters. The In and Out ports are reversed.
    Scott
    Owner of - PoolGuyNJ LLC
    Mar 2011
    Central Florida
    69
    Thanks! So 261050 or 261055 is what I want for the Quad DE?
    Yes, the 261050 or 261055 are the right ones for the Quad DE filters.
    The HiFlow version, 261050, is supposedly a little fancier/more efficient in some way.
    Mar 2011
    Central Florida
    69
    Thanks Jason, my next question was going to be what is the difference between those two. Pentair's site isn't very helpful as far as specifications on those two valves.
    smallwoodst
    Guest
    Quote Originally Posted by BlueWave8 View Post
    About 30 dollars
    They are both six position valves and both pre plumbed.
    I believe the valve design is slightly different.
    I haven't compared them myself, but based on Pentair's claims the more expensive one (261050) has larger channels for the water to flow through, and thus less total resistance to flow. Generally, replacing a single part with a high flow variant makes only a tiny difference that most people can't distinguish. But replacing all of the components in your system with high flow variants can add up to a fairly large difference that you can notice.
    Sep 2013
    Dallas-Ft. Worth Metroplex, TX
    810
    I'm waiting for my plumber to install a Quad DE filter with the 261050 high flow valve. However, the Quad DE has input on the bottom and output on the top.. this valve has the input on the top and output on bottom. Why would this valve be recommended for this filter if the plumbing is reversed?
    EDIT: Never mind. I just took the filter out of the box, and the input is on the top. I could swear I saw a picture of the Quad DE filter online with the input clearly labeled on the bottom. Weird.
    14K Freeform Gunite w/60% Blue Quartz plaster, Quad DE filter, Intelliflo VS Pump + Booster for Cleaner, Aquacal Heat Pump
