Thread: VAC and then Chlorine?
    Cedar Island NC (Outer Banks)
    84
    Pool has a fair amount of algae crud on the bottom (but can see bottom). Should I vac that to waster before starting to dump in my 12% chlorine? or do it together...would seem a waste of chlorine to vac it overboard.?
    This year I WILL like my pool because it will not beat me down as it has in past years!
    Cedar Island NC (Southern Outer Banks)
    Splash Super Pool (40x20)
    29,000 gal; AG; Sand Filter; 1.5HP pump. Use the cosmic Taylor Test Kit
    New Aquarite SWG w/T-15 cell; New Dolphin Supreme M4 Robot cleaner
    Re: VAC and then Chlorine?
    Yeah, vacuum whatever you can to waste so it won't end up in your filter. Then shock to clear any remaining suspended algae, test, adjust, filter, enjoy,
    Clearwater, Florida
    12,000 gallon kidney shaped gunite pool
    Pentair Whisperflo 3/4HP Pump
    Pentair CCP420 420sq/ft Cartridge Filter
    Pentair Intellibrite 5G 120V Pool Light
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,073
    Quote Originally Posted by belgique
    Get as much organic stuff out as you can before you start chlorinating. Otherwise the chlorine will try oxidizing it away, which is a waste.
    Chlorine is for stuff that's too small to catch in the skimmer net!
    I'm with these guys. Just did two runs of vac to waste, did the opening shock and the pool is lookin' good.
    +1 on not letting your pool kick you around. I started early this year and the reward is not having to drain the thing.
    30K gal - IG plaster w/spa, all heated - 3/4HP main pump - Apollo DE filter - TF100XL in use ;)
    Location: Bakersfield, CA, on a district well rich in alkalinity and under a sky rich in dust.
