Thread: Does this filter require backwashing? Purex Triton Sea Hors
    Jan 2011
    Houston, TX
    56
    Hi,
    Here is a thread which has exact same picture as my filter (Purex Triton seahorse):
    purex-triton-sea-horse-any-advice-t7953.html
    Since it is a cartridge filter, I was wondering if they require backwashing. I have read lots of threads about backwashing sand filters but wondered if this one needed it.
    If it does - can you please point me to the switch to set it on backwash mode, on the filter? There is a air valve/bleeding valve on top of the filter but not sure if it is the same one,.
    There is also a backwash setting on the pool plumbing, but I was wondering if you have to set a switch on the filter itself for backwash, or is the pool plumbing valve enough.
    Thanks, Aaron
    15'x30' 10K gal, in-ground, cartridge filter, waterfall, spa, The Pool Cleaner, Purex Triton 250 heater, pool built ~1999.
    Re: Does this filter require backwashing? Purex Triton Sea
    Cartridge filters are not backwashed. You have to disassemble them and clean the element.
    http://www.unicelfilters.com/pool_owner ... _users.asp
    Support the site
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    By the way, there's no backwash valve on your plumbing. The hose spigot is just for draining (slowly).
