Thread: Algae, how long does it take to..............
    ..........grow in the pool plumbing if you don't use the lines. Example, I have a sheer descent and 2 water Lion features that I do not use everyday, I guess no water will circulate in those pipes until I open them up. So, could I get by 2 or 3 days with out circulating water through them? I have probably gone weeks with out opening the valves and no Algae or CCs (knock on wood). Also, how about the vac suction line?. I have gone days without opening that line as well.
    20x40 24,000 gal IG plaster/CircuPool RJ45 SWG/2 skimmer/2sp 2.5hp Jandy Stealth/340sq ft cart filter/600sqftHeliocol Solar Panels/6ft semi circlr tanning ledge/25ft deep end bench/5ft sheer descent/2 lion head water features/1300sqft travertine paver/2 Colorlogic lights/Hayward Navigator/3step 2ft raised bond beam
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Algae won't grow in the lines because it needs sunlight. Bacteria and other critters can grow in there though. I'd want at least daily circulation for a little while on all lines.
    ktdave's Avatar
    Katy, TX
    888
    Re: Algae, how long does it take to..............
    Quote Originally Posted by JCJR
    Sorry for the change of subject JC, but I don't remember seeing your pool. Do you have pictures posted somewhere?
    11,000 gal. gunite w/midnight blue and white pearl PebbleTec
    Intelliflo 4x160 pump
    Intellichlor IC-20 SWG
    Pentair cartridge filter 420 sq. ft.
    Mastertemp 400K BTU heater
    Legend Platinum cleaner
    Pool School
    JasonLion's Pool Calculator
    TF Test Kits
    Sorry for the change of subject JC, but I don't remember seeing your pool. Do you have pictures posted somewhere?[/quote]
    I don't have any pictures yet, only of my pool before my Mom's B-day party held at my house.
    ktdave's Avatar
    Katy, TX
    888
    Sweet!
    Pool School
    TF Test Kits
    very nice!
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
