Thread: Three Tier Fountain tubing replacement
    Aug 2007
    Chesapeake, VA
    41
    The tubing on the 3-tier fountain has deteriorated and it kinda nasty.
    I was looking at replacing the tubing. The local home center store does not appear to stock the tubing.
    The tubing appears to be 1" - 1 1/16"ID with 3/64" wall thickness.
    The tubing is very flexible.
    Has anyone replace this tubing? Any ideas what the material could be? Vinyl, polyurethane...?
    Any ideas would be helpful.
    Steve
    27,000 gal Vinyl Grecian L, Hayward 1 HP pump, Hayward sand filter, Aqua Rite Chlorinator,
    Polaris P955, TF-100, Speed Stir, 400sqft solar panels.
    Jacuzzi J365
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,379
    Re: Three Tier Fountain tubing replacement
    Usually Lowe's, Home Depot, and Ace will have spools of clear plastic tubing in all different sizes in the plumbing area. Take a piece of the current tubing with you to match the size.
    Love TFP? Become a
    TFP Supporter!
    Jul 2009
    Shawnee, Kansas
    92
    Was was going to say try Ace Hardware as well. My Ace stores has tubing like that in about 20 different sizes.
    Matt
    20,000 gallon, sand filter, IG vinyl
    Aug 2007
    Chesapeake, VA
    41
    Thanks for the replies.
    I tried the local home center. No luck at Lowes. That hose has such a thin wall, like less than 1/16", not sure if any home center/hardware store would have it.
    But, what I did find was a replacement hose.
    Poolcenter.com had a replacement hose (PN 11401c) but, it was listed as "Out of Stock for the season"
    So, I called. Turns out their website has old info. They had several in the warehouse.
    I ordered one. Hopefully be here in a few days.
    The fountain helps bring down the TA. I hope to get the cover off the pool this weekend.
    Steve
    Jacuzzi J365
