Results 1 to 16 of 16
Thread: discolored/stained steps?
    Mar 2009
    Indianapolis, IN
    70
    Our pool was just opened today. We drained a small amount of water and noticed that the white plastic steps seem to be stained a rust like color that does not brush away. The skimmer also had rust colored debri on it, some of which brushed away. Also at the end of last year we noticed the metal ring around our pool light was looking rusted/corroded. Any idea what this could be from and how to get rid of the staining?
    18x36 ft
    19,000 gal IG vinyl
    Sand filter Tagelus 24"
    1HP Whisper Flo Pump
    Re: discolored/stained steps?
    Try holding a vitamin C tablet up against some of the stained plastic for 30 seconds and see if that reduces or eliminates the stain in that area.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    How old is the pool? Anything new done to it last season?
    Sounds somewhat like an electrical issue causing electrolysis.
    A vitamin C tablet may clear the stain, which would indicate it's metallic. ETA: Jason beat me to it.
    Mar 2009
    Indianapolis, IN
    70
    The pool is 6 years old. Nothing new has been done. I don't have any vitamin c tablets so I will have to get some to try what you are suggesting. The steps below the water line are totally discolored, not just a small area here and there.
    So if the vitamin C gets rid of the stain it is metals?
    18x36 ft
    19,000 gal IG vinyl
    SW Indiana
    9,199
    Quote Originally Posted by jmlodin
    Yes.
    Mar 2009
    Indianapolis, IN
    70
    Ok I will try the vitamin C tomorrow. If it is metals, how did they get there and how do you get rid of them in the water?!
    Thanks
    18x36 ft
    19,000 gal IG vinyl
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,414
    Metals can come from algaecides, pool heaters, well water, very old metal plumbing, and other pool store treatments such as mineral packs and ionizers.
    Love TFP? Become a
    TFP Supporter!
    Mar 2009
    Indianapolis, IN
    70
    Ok I put a vitamin C tablet on the stain and it went away. So I guess that means the stains are due to metals. What do I need to do now? I do have a jug of Metal Free from the pool store from my pre-BBB days! Is that what I need to use?
    18x36 ft
    19,000 gal IG vinyl
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Here you go...also look at the article refenced in the link
    pool-school/metal%20stains
    Mar 2009
    Indianapolis, IN
    70
    Thank you for the link. I have one follow up question. To take care of the metal problem we have to have chlorine at 0. We are currently in the process of shocking the pool because it was hazy upon opening yesterday. Is it ok to continue to shock until we have clear water and then do the metal treatment? Do the metals have anything to do with hazy water?
    Thanks again!
    18x36 ft
    19,000 gal IG vinyl
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Finish shocking first! The metals don't have anything to do with the haze, and you can't really deal with them til you get the pool clear
    South Central NJ
    3,192
    If the vitamin C doesn't do it, it's likely organic.
    Things I have used to combat this:
    Time chlorinated water will cause it to fade but this can be a somewhat lengthy process.
    Mr. Clean's Magic Eraser
    Jack's Step Stuff
    Scott
    Owner of - PoolGuyNJ LLC
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Just bumping this one as I have steps that have brown/orange discoloration in two locations. Going to try some Vitamin C tablets tonight. I don't see stains anywhere else in the pool at least none that look the same or stand out. Could I just spot treat the area with tablets rather than a full pool AA treatment?
    Isolated Spa - 345 Gallons
    Feb 2012
    Winston Salem NC
    161
    I spot treated my steps, returns, light niche, and drains. I put a emptied a bottle of vitamin c tablets in a panty hose, got the snorkel out and went to work. Took about 30 minutes and all looked as good as new.
    We did not have any staining anywhere else, so the spot treatment made sense to me.
    18x36 IG Vinyl. ~29k Gallons.
    Pentair CCP420 Cartridge Filter
    Pentair Inteli-flow VS Pump
    Hayward Goldline SWG
    Tigershark QC Robot
    Feb 2014
    Central Minnesota
    5,080
    Thanks. I'll give the bag-o-tablets-in-hose method a try for spot treatment.
    Aug 2015
    Raleigh, NC
    4
    I know this thread is old but I tried the techniques discussed here for a similar problem. It worked great. So, I'm posting some pictures for visual effects. The clean looking white spot on the second step in the bottom of the picture is where I let a single Vitamin C tablet sit for 30 minutes. It's perfectly clean! You may also notice that on the top of the picture at the second stop on the stair wall, there's a pretty clean looking section. That's were I took another vitamin C tablet and rubbed against the stain for about 2 seconds and it immediately started to disappear. It's amazing. So I order Jack's Magic Purple stuff for my SWG pool. I'll post that picture in couple of days once I get the results.
    Jay O
    As green as they get about pools
    IG/SWG/17x30x9
    Approximately 2,300 ft3of water
