Thread: Fossil rock for coping
    Has any one had any experience with the white fossil rock slabs for coping? It is very cooling looking and priced rite. It seems hard and not flakey, but the supplier has never sold it for coping, and my PB has no experience with it. Tate
    In ground Pool and spa Specification
    Free form
    18000 Gallons
    7 person spa¬*
    Tr100 Sand filter
    Pacific Blue Hydrozo plaster
    1 3050VS for pool and spa¬*
    Raypac 400btu
    Polairs 280 with booster pump
    Inteli touch automation¬*
    3 Pentair LED's
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Fossil rock for coping
    It probably wouldn't be very durable. Some people do pool coping with limestone/travertine, but I don't think I ever would. It's soft (comparatively) and prone to staining/breakage.
    If you can post a picture of the specific type you're looking at, it would help. There are lots of different fossil-y rocks
    Mar 2011
    Scottsdale, AZ
    406
    Fossil stone, also know as Shell stone, or Marbella stone is used quite a lot around pools here. Though usually quite pricey.
    Most of it ships out of Florida, so it would be cheaper the closer you are.
    It is a softer stone then travertine or limestone, is great for hot areas as it stays very cool.
    One study here showed it was 20 degrees cooler then Acrylic lace decking on over 100 degree days.
    Oct 2010
    Friendswood, TX (near Houston)
    65
    We are using a white limestone for our coping - there are even a few fossiled leaves etc in them.
    What we have heard (not tested yet as we are still a few weeks away from initial fill) is that the harder and denser the stone, the better it will hold up. I am sure a penetrating sealer will also help.
    Very soft stone will probably not be good for coping.
    I guess we will know a lot more in a few years.......
    22000 gallon IGP, 820 sqft, SWG - IC60, infinity edge spa, Pentair Quad DE 100, 3 x Pentair Intelliflow 4x160 pumps (one for circulation + one for spa + one for sheer descents), spa with 8 jets + 4 leg jets, air blower, Pentair EasyTouch 8 remote, Pentair Intellibrites LED (white) - 2 in pool and 1 in spa, Pentair Master Temp 400,000 btu heater, 4 sheer descents (2x2', 2x6'), limestone coping and decking, Pebblesheen Prism Blue
    Useful links:
    Pool Chemistry
    Chlorine reactions
