There is about a 50/50 chance it is an install issue (the installer did put the floats in upside down). I got it to quick sucking, but if you move the hose it will either suck air or leak water. I'll re-install the fittings after the system runs for a little longer today.
I'm not a fan of those type of Speedfit fittings. Has anyone found something that works better? Or am I the only one sucking air? :?
