Results 1 to 7 of 7
Thread: How Much Salt Should My Chorine Generator Use.
    Aug 2007
    League City Texas
    30
    I have a Pentair IC20 Salt Generator. It is designed for up to a 20k gallon pool. My Pool is 12,500 gallons. I have been adjusting the Salt Cell percentage of operation to 33% from 50%. However, I seem to be using about 1 bag of salt per week. How much salt should I expect to use in a pool my size. I also have been noticing I can hardly keep my PH down to the acceptable area. I add Muratic Acid and it brings it down for 1 day and it shoots right back up. I am in Houston and we are experiencing 1 inch of evaporation of water per day, but I was told the salt does not evaporate. This is a new pool and I have never had a salt generator before. Can anyone offer some advice?
    i'VE FALLEN IN AND i DON'T WANT TO GET OUT.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Salt only leaves the pool through leakage, backwashing or splashout. The generator doesn't use the salt, it converts it to chlorine, which then converts back to salt.
    Your pH issue could be due to high TA. Post a full set of test results and we can be of more help.
    ktdave's Avatar
    Katy, TX
    888
    I am in Houston, I have the IC-20. My pool is 11,000 gal. My "pool school" guys added the salt to approx. 3800 ppm (they added 7-40 lb bags of salt). That was 3 weeks ago, I have not added salt, it has been constant since. I don't have automation, so my IC-20 has been running at 40% for 8 hrs./day keeping me at 3.5-4.0 ppm FC per day. I add about a quart of muratic acid per week.
    You should not be using that much salt. Do you have a way of testing your salt concentration? If not, take a sample to your local pool store.
    Salt is a regenerative commodity. It does not get "used up". Unless there is splash-out, rain overflow, or backwashing, etc., you should have as much as you started with. A leak in your system also comes to mind.
    Hope this helps.
    11,000 gal. gunite w/midnight blue and white pearl PebbleTec
    Intelliflo 4x160 pump
    Intellichlor IC-20 SWG
    Pentair cartridge filter 420 sq. ft.
    Mastertemp 400K BTU heater
    Legend Platinum cleaner
    Pool School
    JasonLion's Pool Calculator
    TF Test Kits
    Mar 2007
    Coastalish 'down easter'
    4,160
    Dave, would you mind reposting the 'recalibration' info from the other post (I had just gotten how to x-link on PF when I started coming here and it's a little different, I'll work on it this winter while I'm laid off) Thanks dude!
    Luv& Luk
    -Ted
    Guest
    one inch a day is alot even for tx. i think you have a leak, and thats why your loosing salt so quickly.
    ktdave's Avatar
    Katy, TX
    888
    Quote Originally Posted by waste
    Here it is:
    Intellichlor Recalibration
    Pool School
    TF Test Kits
    Aug 2007
    League City Texas
    30
    I am starting to think I have a leak too.
