Results 1 to 8 of 8
Thread: shocked the pool...
    shocked the pool...
    ok so i shocked my 60,000 indoor pool 3 days ago....to 20 ppm....today still 5+ ppm on my test .....why does it take soooooo long for my chlorine to drop to a safe level?
    60,000 indoor inground pool , with a DE filter made of plaster with a flow rate of 240 GPM and a Aqua Rite SWG.
    South Central NJ
    3,192
    Re: shocked the pool...
    Big pool!
    The four biggest reasons are CYA level, temperature, circulation, and the amount of sunlight hitting it.
    We do ask that you put your pool's specs in your signature and putting your latest test results in your message body. This helps us to help you more effectively.
    Scott
    Owner of - PoolGuyNJ LLC
    Because it is an indoor pool. Chlorine goes away quickly outdoors, and far more slowly indoors.
    You you know your CYA level? If CYA is zero then raising FC up to 20 is way too high.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,602
    I understand that anything in the 10 and under range for FC is ok to swim in?
    Heck........my target level FC is 8 and I jump right in!
    Safe to swim in depends on your CYA level. If you have literally zero CYA then I wouldn't swim at an FC level of over 2, although people do swim up to perhaps 5 some places. As soon as there is even just a little CYA then swimming up to 10 is fine, and as CYA goes up higher FC levels become alright.
    Quote Originally Posted by woodyp
    I try to keep it around 2 ppm. ALSO check the signiture for updated information.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    CYA level?
    Quote Originally Posted by frustratedpoolmom
    CYA level?
    0.00
