Thread: Plaster ratio
    Plaster ratio
    What is the ratio of portland to marble dust?
    Thanks
    14,500 gal pool
    Inground
    Intellichlor Salt Generator
    Water Fall
    Re: Plaster ratio
    Typically 1 pound of cement to 1.5 to 2.0 pounds of aggregate.
    First, the best cement/aggregate ratio is about 1 part cement to 1.5 – 1.75 parts aggregate (marble sand). This produces a higher quality pool plaster product than either richer (more cement) or leaner (more sand) mixes. Plaster that is too rich tends to shrink and crack, and plaster that is too lean is unworkable and isn’t durable. The cement and aggregate should also be selected with care – it needs to be of good quality, consistent, and of an appropriate grade for use in pool plaster. (This also applies to any admixtures.)
    http://poolhelp.com/handouts/oB_Ten%20S ... andout.pdf
    Support the site
