Page 8 of 10 FirstFirst ... 5678910 LastLast
Results 141 to 160 of 190
Thread: I've defected to the dark side! New peristaltic pump
  1. Back To Top    #141
    Re: I've defected to the dark side! New peristaltic pump
    Hmmm....your pool is the same size as mine. I see the specs on the Stenner 45MHP2 is .2 - 3 gpd. I assume for your 13,500 gallon pool that you must leave your pump set at the minimum .2 gpd setting most of the time. That would be adding 1.7 ppm FAC per day, or 1 gallon every 5 days. Just curious where you get your bleach and what you pay. We have a company here in Buffalo that manufactures Chek-Bac Chlorine. It is sold in pool stores and in my local grocery store. Needless to say, I buy it from the grocery store for 3.99 per gallon. According to the bottle, it's labeled as 12.5%, but I do all my calculations as a straight 12%.
    Pool: IG 22k- 16x32 clipped corners- vinyl liner, w/ a great board. Built in 3/99, new to me 2/2011.
    Equip: Hayward 3600 DE filter, Hayward CL-200 Chlorinator (empty since 7/5/2013).
    K-2006 Test kit with Speedstir
    Located in Cincinnati, OH. TFP lurker since 9/2011, BBB interested since 5/2012 and converted 7/2013.
  2. Back To Top    #142
    22,553
    If your talking about my pool, I run my pump 8 hours per day with the dial set between 4 & 5. I use 6% bleach.
  3. Back To Top    #143
    Im still calibrating mine, but I find that the pump is very loud. About as loud as my filter pump on high. I was originally going to run the 45mhp10 at the lowest setting for 8-9 hours, but decided instead to run it for as short a time as possible at the highest setting
    10gpd is actually a fast drip, it is half a gallon per hour so it isnt like the chlorine is pouring out or anything. At the highest setting Im getting about 1.5ppm of CL/hour.
    17,800 gallon, IG pool, 595 sq feet (17x35x4.5 avg rectangle), Hayward 525 cartridge filter, diamondbrite, 2 hp 2 speed hayward tristar filter, Stenner 45mhp10 automatically chlorinating
  4. Back To Top    #144
    May 2012
    North of Charlotte, NC
    312
    I guess with that said I should be fine with 45MHP2(3GPD) as well with the minimal size difference between my pool, and if need be can bump up the tube at a later date for more adjust-ability...Any thoughts on the different series options 45/85 besides the RPM ? And also, any comments on 1/4" or 3/8" supply tubing ?
    24,000 Gallon Vinyl Grecian IG,Triton2 Sand Filter / Pentair Super Flo 1 HP Dual Speed Pump ,
    Stenner Peristaltic Pump Injection w/15 gal drum,Stubbed up supply/return for future solar panels :)
    TF100 Rocks !! Pool School....
  5. Back To Top    #145
    22,553
    The 45's turn at 26 rpm and the 85's turn at 44 rpm. That's really the only difference between the two.
    The 1/4" tubing is plenty big. No use going with the 3/8" unless you're pumping highly viscous fluids.
  6. Back To Top    #146
    May 2012
    312
    Cool thanks Dave..just got my 15gal plastic drum I just the mail today and about to order a peristaltic pump
  7. Back To Top    #147
    May 2011
    Long Grove, IL
    117
    Bama,
    What is the difference between the standard and high pressure Stenner models? Is it just the inline check valve or is there something different in the pump/pump tubes?
    Regards,
    Jay
    Jay
    28,000 gal in-ground hybrid pool with PacFab Superflow 100 sand filter witn VitroClean media, Intelliflo VS pump, Stenner chlorine pump, Raypak R336A Millivolt Natural Gas Pool Heater
  8. Back To Top    #148
    22,553
    The biggest thing is the check valve. However there are a few tubes that aren't rated for 100 psi so the high pressure pumps aren't available in those sizes. The tubes will still fit the pumps, they're just not rated at the higher pressure.
  9. Back To Top    #149
    May 2012
    312
    I've ran across some 1/4" stainless tubing fittings laying around in my garage any issues with using them if I decide rather then plastic on my cl2 injection line? Or maybe just stick with what comes with the pump and tubing.....
  10. Back To Top    #150
    22,553
    There shouldn't be a problem with using the SS fittings but I'd just stick with what comes with the pump.
  11. Back To Top    #151
    ChiknNutz's Avatar
    Jul 2010
    Arlington, WA
    145
    Point to note about the Stenner pumps in general that I found about the hard way this year. Late last year I noticed the pump made some clicking noises and the pump head would sometimes not advance (the motor continuously turns). I have the pump on a relatively low setting at 2 to 2.5 of its 1-10 range. I called Stenner the other day and they said that running the pump at such a low rate wears out the Index Plate sooner than it would if set at a higher setting. As such, they suggest I go to a #1 tube and then set the pump at 7 or 8 which causes the head to move more often. Fortunately, you can take the head apart, pull out the index plate and turn it over to get 2X the life out of it. The plate is about $20.
    Chris A.
    20x40 36k gal IG vinyl pool w/diving board & slide | 1.25HP Pentair Challenger motor & pump | 30" Triton TR100 sand filter | Pentair SM-20-3 multiport | Stenner 45MHP2 Peristaltic Pump & 13 gallon carboy (BBB) | Hayward CL200 Tablet Chlorinator (used on pool startup) | TF-100 | 2003 Sundance 850 Altamar hot tub
  12. Back To Top    #152
    May 2012
    312
    Just got the 45MHP2 in the mail today, pretty nice set-up (fittings ,check-valve,weighted suction strainer) Even came with a spare 100psi #1 Tube , I'm assuming the installed tube is as per nameplate on the pump 3GPD-100psi (no print on it like the spare has) might just shoot them an email to double check...
    Any issues at the injection point with the 3/4" long excess tubing (after the threads) that would be in the flow path in the return line, trim it down or leave it alone?
    Looks like a pretty sweet set-up and cant wait to set it up and dial it in to maintain my 5-6 FC levels and looks like I'll have it set before I go away for a week or so and don't have to worry about asking the house/dog sitter to mess with any chlorine dosing
  13. Back To Top    #153
    22,553
    I'd leave it alone. It won't hurt anything sticking into the piping.
    The tube will match the nameplate size.
  14. Back To Top    #154
    May 2012
    312
    Thanks Dave, will update with results after tuning and may even post a couple pics of my temporary set up for now until I get a chance this fall to rearrange my pump house/piping/pad....
  15. Back To Top    #155
    May 2012
    312
    Yep. Just drill and tap the PVC pipe. Use a few wraps of t-tape or some paste on the threads and you'll be good.
    Injection Quill installed Drilled and tapped through the fitting hub and pipe (a little more threads through both) Thread sealant and shes holding like a champ...put a isolation valve in to for servicing the check valve if needed Next is just filling the 15 gal drum and installing/wiring my time-clock, at least I think I have my dosing down manually to about 40-50 oz per day (12.5%) and maintaining 4.5-5.5 FC , so dialing in the pump shouldn't be that difficult ...
  16. Back To Top    #156
    22,553
    Looks good so far. Post more when you have them!
  17. Back To Top    #157
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Is the valve stainless? I used a brass fitting for my injection point, and now need to replace it after only a couple of years in service.
    Ike
  18. Back To Top    #158
    May 2012
    312
    Thanks, will do...I'm off this coming week (finally) and will be finishing up everything
    Yep..SS..we'll see how it holds up to 10-12% Hypo
  19. Back To Top    #159
    May 2012
    312
    Ok..I finally have my stenner pump in service..im running my pump from 8 am till 8pm every day and injecting when the pump runs..Im in the process of dialing my FC level in, my question is when is it best to pull a sample in a consistent way , before the pump runs in the AM or at night an hr or so after its off? Or do I need to dial it in on both ends of the 12 hour run time?
  20. Back To Top    #160
    22,553
    You should actually catch a sample about an hour after the pump starts in the morning. That way it hasn't had time to inject enough chlorine to affect the test but has had time to circulate the pool water.
