Results 1 to 11 of 11
Thread: Pump/Filter questions
    Apr 2010
    Central Illinois
    205
    Hello,
    We are in the process of getting an above ground pool (install date is 4/25). I need to know if we get an inground pool pump vs. above ground pump, will we need the same HP? Also, would we need to get a filter for an inground or can we stay with an above ground cartridge filter? Would we need the same size filter? Are there any cons to getting an ig pump for an above ground pool?
    FYI, by being to put the equipment next to the house, it is saving us a lot of $$$$ on running the electrical and gas. (we are getting a heater too.)
    Any advice is greatly appreciated!!!!!
    15x30x54 AquaLeader Sentinelle AGP
    2 HP 2 Speed Hayward SwimPro Voyager Pump
    Hayward SwimPro Voyager 150 sq. ft. Filter
    Hayward H series millivolt 150 btu Heater
    TF-100
    Re: Pump/Filter questions
    If you have a typical above ground setup, with the pump near the pool and short hoses then you should get an above ground pump. If you have long plumbing runs, say 30 feet each way or more, then an in ground pump would probably be appropriate. Another thing to watch out for is the position of the pump relative to the water line of the pool. Typically an above ground pump only works when it is below the pool water line. If your pump needs to be above the water line for the pool then you need a pump that is self priming. All in-ground pumps are self priming, but only a couple of the above ground pumps are.
    The recommended HP is essentially the same for in-ground vs. above ground. With pumps, smaller is generally better, unless you have a spa, waterfall, or other water feature that requires a larger pump.
    You can use any kind of filter on either kind of pool. With filters larger is better, as a larger filter needs to be cleaned less often and filters better than a smaller filer.
    22,548
    There are no serious issues to using an inground pump on an AGP and since you're burying it, you're probably better off with an inground pump. However, the HP you have listed in your sig is WAY too big for your pool. I'd recommend a 3/4 or 1 hp 2-speed pump. I'd also go with a larger filter.
    I'd probably want a 150"K" btu heater too.
    Apr 2010
    Central Illinois
    205
    Can anyone recomend a model name or number of a good ig pump? Can I mix and match brands?
    When talking about "runs" what do you mean exactly? The pipes from filter/pump to pool?
    TF-100
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    You can mix brands. Hayward Tristar, Pentair whisperflo, and Jandy e-pump all come in low-HP 2-speed models and are pretty much comparable in price and performance.
    A "run" is the distance from the pool to the equipment.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    I have a 0.5HP pentair superflo...love it, nice and quiet on a slightly oversized hayward sand filter S220T
    mas985's Avatar
    Pleasanton, CA
    11,737
    A couple of things that may not have been mentioned:
    AG pumps tend to have lower max head the IG pumps which makes them slightly more efficient than an IG pump of the same THP. But because of lower max head, AG pumps may not be suitable for solar installed on a roof but it depends on the pump.
    Most AG pumps are up rated while IG pumps are both up and full rated so when comparing make sure you compare the appropriate pumps.
    AG pumps tend to cost less than an IG pump of the same THP.
    If solar is not an issue and run lengths are short, then an AG pump may be more economical overall.
    Mark
    Apr 2010
    Central Illinois
    205
    Quote Originally Posted by mas985
    Im not understanding the whole "head" & "up/full rated". I have to measure the length between the house an equipment. Does that affect anything? We are going to have a gas heater. I need help!!!!!!
    TF-100
    mas985's Avatar
    Pleasanton, CA
    11,737
    Up rated pumps have a low motor service factor while full rated pmps have a higher motor service factor. A 1 HP up rated pump will have the same performance as a 3/4 HP full rated pump in the same product line. So you just need to be careful when choosing a pump and make sure you know what you are getting.
    As far as head goes, high head just means that the pump can produce higher pressure. This is useful for pressure side cleaners, running solar and pushing water through lots of pipe (in-ground). If you plan on putting solar on your roof then I would go with an IG pump and one of the most efficient two speed is the Pentair WFDS-3 (3/4 Hp full rated dual speed) and WFDS-24 (1 HP Up rated dual speed). Both have exactly the same performance even though they are labeled differently. Even if you don't plan on solar, they are still not a bad choice but will be more expensive than a AG pump.
    Mark
    Apr 2010
    Central Illinois
    205
    The pool store i am getting my pool from only sells the Hayward 1.5 HP Super Pump. None of the pool stores in my area sell 2 speed pumps (they say they dont work). What is a reputable and cheap online store to purchase a pump and filter?
    TF-100
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,380
    I ordered my last pump from Pool center. I was happy with the quick delivery and the product was as advertised except for the power cord. It didn't come with one and I thought it did. It was a simple fix on my end.
    Love TFP? Become a
    TFP Supporter!
