Results 1 to 12 of 12
Thread: Question about our Polaris ?
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    Is there a certain length that the hose from the polaris that attaches to the outlet/return needs to be or do we just leave it the length it comes from the store. The reason I'm asking is the head part always seems to get caught up in the hose and doesnt do a very good job of cleaning off the bottom of the pool.
    Also is there anyway I can keep it from getting hung up in the stairs ?
    Les
    Don't have a pool right now. Just sharing what I have learned over the years!
    Helpful Links:
    Pool School,Pool Calculator,Cl/CYA Shock Chart,TF Test Kit
    Doing BBB and loving it!
    ivyleager's Avatar
    Sep 2007
    Raleigh-Durham,NC
    489
    I have a Polaris 360, and the manual states that the length needs to be measured from outet (pressure or suction) to farthest point of pool. Then, actual hose length should be within +/- 6 inches of this distance. Mine does not get hung up on steps or ladders, so I can't help you there.
    Good luck, and hope this helps.
    CaryB
    CaryB
    36 x 18 IG vinyl, 25K, 1 HP pump, sand filter
    1 skimmer, 2 returns, no main drain
    Old school: PoolSolutions test kit
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    Ours always seems to want to go to the left and keeps trying to get hung up on the hose. Not sure if there is something wrong with it or not.
    Les
    Helpful Links:
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    Ok, call me a bone head. I think I have just discovered the trouble ! We didnt realize the hose was for a 24' round pool that comes with the Polaris .... SO ... having found this out we will cut it down to 18' and see what happens. Hopefully this will correct the problem of it always wanting to go left all the time ....
    Les
    Helpful Links:
    ivyleager's Avatar
    Sep 2007
    Raleigh-Durham,NC
    489
    Does your Polaris have a cylindrical nob at the back upper left corner? mine works best when set between 9-11 o'clock. This nob is supposed to control for turning, backing up, etc. Also, is your sweep tail fast or slow? Again, my 360 works best when tail is moving slow. Lastly, does your unit back up every 3-5 minutes? It's supposed to do so routinely, therefore it shouldn't get hung up on other pool obstacles.
    Hope this helps.
    CaryB
    CaryB
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    Ours is the Polaris 65 model and I didnt see any control knobs on it. I think tomorrow I will trim the hose length to 18' throw it in and see what happens ....
    Les
    Helpful Links:
    ivyleager's Avatar
    Sep 2007
    Raleigh-Durham,NC
    489
    I used our prior Polaris 165 (inground model) for target practice. It worked well for the first year, then it went down fast. and yes, it did only turn one way, and got hung up in it's own hose 90% of the time.
    CaryB
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    Last year one of the jet ports stoped working on this one and we had to take it in. The pool place said it "blew a piston" inside somewhere and thats why it wasnt working right. OUr model we have has a blue top, your has a grey one if I'm not mistaken. I will shortne the hose and see what happens and if it still get hung up I guess I will have to take it in again. Maybe I can get it to work just long enought o get the "junk" off the bottom of the pool so we ca get it covered then take it in to be looked at .....
    Les
    Helpful Links:
    Jul 2007
    Suwanee, GA
    528
    The shorter hose will help and the reversing jet should get it off the stairs if it gets stuck. My polaris aways seemed to go to one spot in the deep end when the reverser fired, and I figured out it's because the pool return was pushing on the floating hose. I pointed that return down even though it still seemed to clean the pool well.
    Gary
    Gary
    21k gal SW, IG Gunite PebbleSheen, 1HP Jandy, Jandy 340 filter, Polaris 280, 17' fiberglass slide w/ 2HP pump.
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    Crabboy, we have an AG pool with only one return so our Polaris line gets hooked into that return. I think if I shorten the hose that might help. We are going to pull the steps tonight because we are putting on a leaf cover to keep that problem at bay while they fall , so Im hoping that will do the trick. If not we have until April to get it figured out Actually believe it or not (just my luck) one morning I went out and the Polaris had gone BETWEEN the ladder rails and got stuck there ! Dont ask how that happened !
    Les
    Helpful Links:
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    Ok, so who else besides me thinks that 16 feet looks like 18 feet on a tape measure I hope you can buy Polaris hose at the pool store
    Les
    Helpful Links:
    Greetings--
    Check the Polaris web site. It has information on hose lengths, spacing of floats, ect. Apparently this is a fairly exact requirement.
    We had a lost of trouble with ours tangling up in its own line. We cut the hose lengths to spec and that helped some.
    Another tip I found out about was about the hose's flexability. It was suggested that if tangles were a common occurance, the hose was not longer as flexible as needed. I was told to lay the hose out in the sun for a couple of hrs to let it warm up. Place it back in the pool and let the beast run. Notice-- if it stopped tangling, then the old hose was too stiff and needed replacing.
    - Reji
