Page 1 of 5 1234 ... LastLast
Results 1 to 20 of 99
Thread: new pool Petaluma Ca
    Feb 2011
    Petaluma, Ca
    665
    Alot has been completed already, I just hav'nt found the time to post. Here's a few to get started.
    DONE, 20 x 40, inground gunite, 30" raised bond beam with 3 12" sheer descents, 8' diving board, pentair 420 cartridge filter, vs-3050 pump, intellechlor ic-40, auto cvr, Tahoe blue pebble tech, 6ea 4' x 12.5' & 2ea 1' x 12.5' helicol solar panels, legend robotic cleaner.
    Feb 2011
    Petaluma, Ca
    665
    Re: new pool Petaluma Ca
    a couple more. What a mess.
    Feb 2011
    Petaluma, Ca
    665
    getting a little closer
    Feb 2011
    Petaluma, Ca
    665
    I wish you could post more than 3 at a time.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    looking really good!!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    I had to study one of those pictures closely. I have a cousin in Petaluma who has a tractor service and has dug a few pools. But it wasn't him driving the bobcat. No way he'd wear white tennis shoes. Ever.
    Mar 2007
    San Rafael, CA USA
    12,082
    By any chance is your pool builder Janssen Pools? That's who did our pool. I figure your being in Petaluma it might be the same PB.
    Feb 2011
    Petaluma, Ca
    665
    Quote Originally Posted by chem geek
    It's Herbs Pool service. They were originally based in Marin but also have a base in Petaluma that they opened some years ago.
    Feb 2011
    Petaluma, Ca
    665
    here's a few more.
    Mar 2007
    San Rafael, CA USA
    12,082
    Quote Originally Posted by bobby1017
    I've very familiar with Herb's since that's where I get my chlorinating liquid and miscellaneous parts and chemicals in San Rafael. I knew they had a pool service with thousands of customers, but didn't know they built pools as well though I can see they mention that on their website.
    crookm11's Avatar
    Jun 2010
    Copperas Cove, Texas
    422
    The pool is looking great. Keep us updated.
    Mark Crook
    13,500 Gallon 24' x 52" Intex Ultra Frame
    Intex Sand Filter and Pump, Intex SWG (All hard PVC plumbed)
    TFTestKit-100---Pool School---The Pool Calculator
    Location: Copperas Cove, Texas --- My Pool Build---Useful Links for Intex Pool Owners
    Feb 2011
    Petaluma, Ca
    665
    Here are a few more.
    Feb 2011
    Petaluma, Ca
    665
    getting close to current.
    Feb 2011
    Petaluma, Ca
    665
    decking work.
    Mar 2007
    San Rafael, CA USA
    12,082
    The pool and deck are looking really good. From the equipment pad, I can see your Pentair VS-3050 pump. Looks like you've also get a booster pump for a pressure-side cleaner on a dedicated line. I can also see your saltwater chlorine generator. You've got an oversized cartridge filter which is good since you won't have to clean it as often.
    What's the Jandy valve and pipe going towards the back next to the filter for? I don't see plumbing for solar panels though you mention those in your signature line -- is that the valve and pipe in the back switching to go to solar and if so, where does it come back? The pipes coming forward clearly go to the returns on the right; to pool cleaner in the middle; and suction lines on the left (why are there Jandy valves for the 2 suction and 2 return lines? Individual valves for each line I can understand and see those as well). You note an automatic pool cover and that will help to retain heat in the pool by eliminating evaporation.
    Feb 2011
    Petaluma, Ca
    665
    Those are for the solar, there are 2 pipes, one is hidden in the picture. The valve allows the flow to be adjusted & turns on or off depending if the sun is out. I'm not totally familiar with the solar sys or all the equipment yet.
    Feb 2011
    Petaluma, Ca
    665
    Worked on landscaping this weekend and the pebblecoat gets applied on Wednesday. I guess after approx 10 days the water will have "stabilized" and the auto cover will be installed then and other than cold water it will be ready. My solar racks are going to be the holdup as I'm doing them myself and as usual have too many things going on.
    Feb 2011
    Petaluma, Ca
    665
    auto cover coping brackets, me in the pool, shot of the backyard.
    Feb 2011
    Petaluma, Ca
    665
    some landscaping, all done by me & Daniella. Needs alot of work but it's a start.
  20. Back To Top    #20
    Feb 2011
    Petaluma, Ca
    665
    No pebble tech tomorrow, there are still some spots on the wall that are seeping too much water, I guess they are drilling some holes in the wet spots to aid drainage. They are all on the wall covered in shadow in the picture with me in the pool. There are 6 spots that will be drilled.
