Thread: The Pool Cleaner and Baracuda X7 in Action
    phalcon51's Avatar
    Oct 2010
    So. California
    203
    Well, I had 2 pool cleaners laying around, a new toy to play with and some time to kill this last weekend so I decided to make a couple of videos of the cleaners in action. I recently got a GoPro HD camera. It comes with a waterproof housing and a variety of mounts. I used the 3" suction cup mount to attach it to the wall just under the waterline in the deep end of the pool. I then set the camera to take a picture every 2 seconds and started the cleaner and let it run for 2 hours. After downloading pictures to my computer I used MakeAVI to create an .avi video from the stills. I then used Windows Live Movie Maker to add titles at the beginning and end and uploaded them to YouTube.
    And now, after hours of production are the stars you've been waiting to see! Grab your popcorn, relax, put up your feet and watch. Critiques welcome!
    [youtube:1gp5ciz8]CFEKW0G3JnM[/youtube:1gp5ciz8]
    2 Hour Cleaning Cycle in 4 Minutes. Here's a time-lapse video of The Pool Cleaner by Poolvergneugen in my pool. It was set up according to the included instructions with the R.H. drive wheel set to turn 11-13 rpm. This is a suction side cleaner, so it vacuums directly to your filter. I have a Hayward leaf-catcher in-line to catch the larger bits of sand, gravel or twigs. The Pool Cleaner randomly scoots around the pool and does a very good job of sucking up sand, gravel, leaves, small twigs and dead bugs. Ocassionally it will get stuck in a corner trying to climb the wall, but after about a minute it will rotate to a new direction and move on. In one instance it managed to flip over backwards in a corner, then fell on its side and crabbed around for about 10 seconds, righted itself and continued on. It covers the entire pool, deep and shallow end and partway up the walls, and over a few days at a couple of hours a day it seems to cover the entire pool. So far, I'm very happy with it compared to the two other cleaners I've tried. I'd recommend it.
    [youtube:1gp5ciz8]9SrLAnXybus[/youtube:1gp5ciz8]
    2 Hour Cleaning Cycle in 4 Minutes. Here's a time-lapse video of the Baracuda X7 in my pool. It was set up according to the included instructions with the supplied suction gauge set to 3. My main concerns are that it spends very little time in the shallow end of the pool and a lot of time on the walls and going in big circles in the deep end. In one instance it climbed straight up the corner in the deep end and sat at water level, sucking air into the pump until it completey lost suction. Even then, it didn't submerge, it just sat there sucking air. Luckily, I was home at the time or it would have probably burned out my brand new pump. It has difficulty picking up sand and dirt and it also has a tendency to simply push debris out of the way instead of vacuuming it up. I can't say I'm really happy with it, but you can make up your own mind
    26,200 gal. 35' x 16' Plaster IGP (50 yrs. old), Hayward 48 sq. ft. DE filter, Hayward EcoStar VS pump, Intellichlor IC-40 SWCG, The Pool Cleaner 4X suction, Pool Skim and Pool Devil skimmers. Re-plastered Sept. 2010.
    30,432
    Re: The Pool Cleaner and Baracuda X7 in Action
    Are the links missing?
    phalcon51's Avatar
    Oct 2010
    So. California
    203
    No, no links missing. You should be seeing a still frame from each of the video files with a big "start" arrow in the middle of each one and the "YouTube" logo in the bottom right. It's a direct YouTube embed. I'm seeing it just fine. Anyone else having a problem with it? If so, please let me know. In the meantime, here's a couple of direct links to the vids:
    The Pool Cleaner:
    http://www.youtube.com/watch?v=CFEKW0G3JnM
    Baracuda X7:
    http://www.youtube.com/watch?v=9SrLAnXybus
    Thanks for watching!
    Gary
    pool1999's Avatar
    Mar 2011
    727-Florida
    84
    Great Job, pass the butter!
    Anton and Michele
    11.5K Gallon (14X30), In Ground Fiberglass Pool, Hayward Aqua Rite Salt Chlorinator, Hayward Super II 1 hp Pump, Hayward Star Clear Plus 90sqf Cartridge Filter, TF100 Test Kit, BBB
    Well ok, the construction is still ongoing but i just want to dump SOME bleach in that dang pool
