Results 1 to 18 of 18
Thread: Ok everything is just about perfect with the BBB BUT........
    I can't find any information about adding salt to a swimming pool that has no salt water chlorine generator.
    I know Jason said I could and I've read somewhere else that they have added salt to a regular chlorine pool,but no matter how I ask the question on a search engine....they don't seem to understand that I don't have a swcg and I don't intend to install one....I just want to know the correct way to add salt to a regular pool and what the salt solution limits would be.
    Thank you in advance.
    And thank you all so much for helping get this BBB set up and straightened out.
    11000 gal L shaped gunite pool with and aggragate plaster
    Pentair cartridge filtration with 1.5 hp pump
    only have 3 returns and one dedicated vacuum line
    manifold to pump is three valve
    22,550
    Re: Ok everything is just about perfect with the BBB BUT....
    Here's the down and salty of it!
    1. Test your water to see how much salt is in there now.
    2. Use the Pool Calc to determine how much salt you need to bring it to about 2000 ppm.
    3. Go to your local Pool or big box store and buy that much salt.
    4. Turn on your pump and let it run for at least two days after adding salt.
    5. Start dumping in all the bags of salt that you got in #3.
    6. Stir the salt around with your pool brush, etc until it's dissolved.
    7. Return your pump to it's regularly sechduled program after two days.
    8. Dive in and enjoy!
    This portion of Pool School mentions the type of salts you should use...
    pool-school/recommended_pool_chemicals
    24' Round 54" Impulse Ovation AGP, 1.5 HP 2 Spd, 150 Sq Ft. Cartridge Filter, RayPak 130K BTU NG Heater, BBB in full effect!!
    Vist TFT Test Kits --- Visit Pool School ---
    Visit the Pool Calculator
    benavidescj's Avatar
    Apr 2010
    Fleming Island, FL
    431
    4. Turn on your pump and let it run for at least two days.
    Curious why you need to do this?
    Carlos
    Pool: 28,000 gallons IG; IC 40 SWG; Pentair 120 gpm cartridge filter; Marble finish; Pentair Wisperflow 1.5 hp; Polaris 360
    Spa: 350 gallon; Bromine
    How to shock your pool
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,609
    Would this actually make the water "feel" better even without a SWCG? If so, I might be interested myself.
    22,550
    Just to make sure the salt is completely mixed in the pool water. It really wouldn't hurt anything if you didn't, but you may have spots of high salinity water for a while if you don't.
    Woody -- People say it makes the water softer.
    Apr 2010
    Fleming Island, FL
    431
    Oh... I think you wanted that to be the step after you add salt. The way it is written it seemed to me something you would do prior to adding salt. Then again, I am stupid at times.
    Carlos
    22,550
    Thanks, After rereading it, it did sound like I wanted it ran for two days prior to adding the salt. I edited the post to make it clearer.
    May 2009
    Marion, Ohio
    32
    We've done this for 2 years now - trust me it makes the water feel much softer and your skin feels a lot better after you get out! Use the solar salt - just dump it in and enjoy!
    10,000 gallon inground vinyl FOXX pool - built in 1999. Hayward sand filter. 3/4 HP 2-speed pump with timer. Hayward Aquarite SWG t-3 cell. Love the BBB method - pool has never looked better!
    joshearl's Avatar
    Apr 2011
    Northern California
    61
    This sounds like something I may want to try. It seems fairly cheap to try but are there any negative's or does it change any other conditions in a normal plaster chlorine pool? Also, how fast does salt last, how often will I have to add more?
    25,000gal Plaster
    Pentair Nautilus NS-60 DE Filter
    Salt can damage some of the softer natural stones. Otherwise, no disadvantages.
    Salt is only lost to splash out, backwashing, and overflow. Normally you only need to add some more once per season.
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    We did that for a long time before we went to a SWG. It felt great and loved it. Then we thought, if it's already in there, lets make use of it. Got a SWG, so now if feels great and works for us too.
    18x33x52 Buttressfree Seaspray (Wilbar) AGP - 1.5hp Pentair Maxim w/22" Pentair Meteor Sand Filter, Aqua Rite SWG System, Biltmore Walk In Steps - 2/4x20 Solar Panel Setup - Doheny Jet Drive (RIP -Pool Rover Jr) - finally hard plumbed the whole darned thing -
    Beats Driving to the Lake!
    Dayton, Ohio
    79
    I ws reading this post and am not quite sure why you would use salt without a SWG? Does it just make the water feel better on the skin?
    AG Intex Ultra Frame
    Round 16 ft x 48 in, 5061 gal
    2500 gph Intex Krystal Clear Cartridge Filter
    BBB
    Mar 2007
    San Rafael, CA USA
    12,082
    Quote Originally Posted by cmbutterbaugh
    Yes, some people say that it makes the water feel silkier. It is also much easier on the eyes open in the water since the higher salt level of 3000 ppm is closer to that of human tears of 9000 ppm so there is less osmotic pressure from water entering the eye.
    Aug 2010
    Livonia, MI
    18
    This is probably a *really* dumb question, but should everyone stay out of the pool for the 48 hours while the pump is circulating the salt? I often have this same question, regardless of the chemical/additive being discussed. If anyone can point me to a good thread regarding when to stay out and when it's OK to get in, I would be grateful. I have so much to learn, even though I spend pretty much every night here, reading! TIA!
    - Michelle in SE Michigan (suburban Detroit)
    54" Desert Spring Doughboy 21x41' oval AG pool, with 7' deep end on half the pool - approximately 23,000 gallons. Including 2 returns/skimmers/main drains, 300lb Doughboy sand filter, 2HP Doughboy pump.
    Salt is harmless, you can swim while adding salt if you want to. The same goes for baking soda. It is best to stay out for half an hour when adding bleach or chlorine to make sure you don't swim through a high concentration before it mixes in thoroughly.
    joshearl's Avatar
    Apr 2011
    Northern California
    61
    Not to hijack this thread, but would it be safe to swim while adding borax? Also, is the proper way to add borax just to spread all around the perimeter?
    25,000gal Plaster
    30,421
    I would prefer to see borax added slowly through the skimmer but around the pool and then brushed off the pool floor (if necessary) will work, too.
    Perfectly safe to swim in a pool having just put borax in.....no time limit
